创建网站与数据库步骤
246
数据库:root/root
数据库访问地址:http://www.foodmate.cc/god/
记得要在mysql数据库里执行命令
create database tjj default charset utf8;
grant all on tjj.* to tianjiaji@localhost identified by "4acfb9baa8";
flush privileges;
创建用户
useradd -s /sbin/nologin malla
修改密码
passwd malla
创建虚拟主机
在:vi /usr/local/nginx/conf/nginx.conf
server
listen 80;
server_name malla.foodmate.cc;
index index.html index.htm index.php;
root /home/malla;
#limit_conn crawler 20;
location ~ .*.(php|php5)?$
#fastcgi_pass unix:/tmp/php-cgi.sock;
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
include fcgi.conf;
查看加载的是否正确:
/usr/local/nginx/sbin/nginx -t
/usr/local/nginx/sbin/nginx -s reload
安装后的访问地址:
http://malla.foodmate.cc
修改权限:chmod -R 777 malla
