打通linux的tty驱动的数据链路
一、首先把tty驱动在linux中的分层结构理清楚:
自上而下分为TTY核心层、TTY线路规程、TTY驱动。
二、TTY核心层与线路规程层分析
用户空间的程序直接对tty核心层进行读写等相关操作,在tty_io.c中:
int__init tty_init(void)
cdev_init(&tty_cdev,&tty_fops);
if(cdev_add(&tty_cdev, MKDEV(TTYAUX_MAJOR, 0), 1) ||
register_chrdev_region(MKDEV(TTYAUX_MAJOR, 0), 1, "/dev/tty")< 0)
panic("Couldn‘tregister /dev/tty drivern");
device_create(tty_class,NULL, MKDEV(TTYAUX_MAJOR, 0), NULL, "tty");
以上的一段初始化代码可以获取以下信息:
注册了一个字符驱动,用户空间操作对应到tty_fops结构体里的函数:
staticconst struct file_operations tty_fops = {
。llseek =no_llseek,
。read =tty_read,
。write =tty_write,
。poll =tty_poll,
。unlocked_ioctl =tty_ioctl,
。compat_ioctl =tty_compat_ioctl,
。open =tty_open,
。release =tty_release,
。fasync =tty_fasync,
对于字符设备驱动,我们知道,读写操作一一对应于fops.
tty_open:
static int tty_open(struct inode *inode, struct file *filp)
int index;
dev_tdevice = inode->i_rdev;
structtty_driver *driver;
driver= get_tty_driver(device, &index);
tty= tty_init_dev(driver, index, 0);
retval= tty_add_file(tty, filp);
if(tty->ops->open)
retval= tty->ops->open(tty, filp);
get_tty_driver是根据设备号device,通过查找tty_drivers全局链表来查找tty_driver.
tty_init_dev是初始化一个tty结构体:
tty->driver= driver;
tty->ops= driver->ops;
并建立线路规程:
ldops= tty_ldiscs[N_TTY];
ld->ops= ldops;
tty->ldisc= ld;
其实tty_ldiscs[N_TTY]在console_init中确定,该函数在内核启动的时候调用。
tty_register_ldisc(N_TTY,&tty_ldisc_N_TTY);
则:tty_ldiscs[N_TTY]=&tty_ldisc_N_TTY;
struct tty_ldisc_ops tty_ldisc_N_TTY = {
。magic = TTY_LDISC_MAGIC,
。name = "n_tty",
。open = n_tty_open,
。close = n_tty_close,
。flush_buffer = n_tty_flush_buffer,
。chars_in_buffer= n_tty_chars_in_buffer,
。read = n_tty_read,
。write = n_tty_write,
。ioctl = n_tty_ioctl,
。set_termios = n_tty_set_termios,
。poll = n_tty_poll,
。receive_buf = n_tty_receive_buf,
。write_wakeup = n_tty_write_wakeup
tty_add_file主要是将tty保存到file的私有变量private_data中。
tty->ops->open的调用,实则上就是应用driver->ops->open.这样,我们就从tty核心层到tty驱动层了。
tty_write:
static ssize_t tty_write(struct file *file, const char __user *buf,
size_t count, loff_t *ppos)
ld= tty_ldisc_ref_wait(tty);
if(!ld->ops->write)
ret= -EIO;
else
ret= do_tty_write(ld->ops->write, tty, file, buf, count);
从以上这个函数里,可以看到tty_write调用路线规程的write函数,所以,我们来看ldisc中的write函数是怎样的。经过一些操作后,最终调用:
tty->ops->flush_chars(tty);
tty->ops->write(tty,b, nr);
显然,这两个函数,都调用了tty_driver操作函数,因为在之前的tty_open函数中有了tty->ops=driver-> ops这样的操作。那么这个tty_driver是怎样的呢,在TTY系统中,tty_driver是需要在驱动层注册的。注册的时候就初始化了ops, 也就是说,接下来的事情要看tty_driver的了。
tty_read:
static ssize_t tty_read(struct file *file, char __user *buf, size_t count,
loff_t *ppos)
if(ld->ops->read)
i= (ld->ops->read)(tty, file, buf, count);
else
i= -EIO;
像tty_write的一样,在tty_read里,也调用了线路规程的对应read函数。不同的是,这个read没有调用tty_driver里ops的read,而是这样:
uncopied= copy_from_read_buf(tty, &b, &nr);
uncopied+= copy_from_read_buf(tty, &b, &nr);
从函数名来看copy_from_read_buf,就是从read_buf这个缓冲区拷贝数据。实际上是在tty->read_buf的末尾 tty->read_tail中读取数据。那么read_buf中的数据是怎么来的呢?猜想,那肯定是tty_driver干的事了。
tty_ioctl:
long tty_ioctl(struct file *file, unsigned int cmd, unsigned long arg)
switch(cmd) {
case… …… :[!--empirenews.page--]
就是根据cmd的值进行相关操作,有对线路规程操作的,有直接通过tty_driver操作的。
三、TTY驱动层分析
接下来看,TTY驱动层是怎样的:
TTY驱动层是根据不同的硬件操作来完成相应的操作,这里我们以串口为例。
串口作为一个标准的设备,把共性的分离出来,就成了uart层,特性成了serial层。
主要是serial层作为一个驱动模块加载。以8250.c为例:
static int __init serial8250_init(void)
serial8250_reg.nr= UART_NR;
ret= uart_register_driver(&serial8250_reg);
serial8250_register_ports(&serial8250_reg,&serial8250_isa_devs->dev);
#define UART_NR CONFIG_SERIAL_8250_NR_UARTS
CONFIG_SERIAL_8250_NR_UARTS是在配置内核的时候定义的,表示支持串口的个数。
static struct uart_driver serial8250_reg = {
。owner =THIS_MODULE,
。driver_name ="serial",
。dev_name ="ttyS",
。major =TTY_MAJOR,
。minor =64,
。cons =SERIAL8250_CONSOLE,
在驱动层里有几个重要的数据结构:
structuart_driver;
structuart_state ;
structuart_port;
structtty_driver;
structtty_port;
实际上,理清了这几个结构体的关系,也就理清了TTY驱动层。
uart_register_driver:
这个函数主要是向TTY核心层注册一个TTY驱动:
retval= tty_register_driver(normal);
其中normal是tty_driver.
另外,还会对tty_driver和uart_driver之间进行某些赋值和指针连接。我们最关心的是,给tty_driver初始化了操作函数uart_ops,这样,在tty核心层就可以通过uart_ops来对UART层进行操作。
serial8250_register_ports:
最重要的两个函数:serial8250_isa_init_ports和uart_add_one_port
serial8250_isa_init_ports主要的工作是初始化uart_8250_port:开启定时器和初始化uart_port.
uart_add_one_port顾名思议,就是为uart_driver增加一个端口,在uart_driver里的state指向NR个slot, 然后,这个函数的主要工作就是为slot增加一个port.这样,uart_driver就可以通过port对ops操作函数集进行最底层的操作。
现在来分析下连接部分,也就是tty_driver如何工作,如何连接tty核心层(或者ldisc层)和串口层uart_port.关于操作部分主要是uart_ops.
uart_open:
staticint uart_open(struct tty_struct *tty, struct file *filp)
retval= uart_startup(tty, state, 0);
staticint uart_startup(struct tty_struct *tty, struct uart_state *state,int init_hw)
retval= uport->ops->startup(uport);
调用了uart_port的操作函数ops的startup,在这个函数里作了一些串口初始化的工作,其中有申请接收数据中断或建立超时轮询处理。
在startup里面申请了接收数据中断,那么这个中断服务程序就跟读操作密切相关了,从tty核心层的读操作可知,接收到的数据一定是传送到read_buf中的。现在来看是中断服务程序。
调用receive_chars来接收数据,在receive_chars中,出现了两个传输数据的函数:
tty_insert_flip_char和tty_flip_buffer_push.
static inline int tty_insert_flip_char(struct tty_struct *tty,
unsigned char ch, char flag)
struct tty_buffer *tb = tty->buf.tail;
if(tb && tb->used < tb->size) {
tb->flag_buf_ptr[tb->used]= flag;
tb->char_buf_ptr[tb->used++]= ch;
return1;
return tty_insert_flip_string_flags(tty, &ch, &flag, 1);
当当前的tty_buffer空间不够时调用tty_insert_flip_string_flags,在这个函数里会去查找下一个tty_buffer,并将数据放到下一个tty_buffer的char_buf_ptr里。
那么char_buf_ptr的数据怎样与线路规程中的read_buf关联的呢,我们看,在初始化tty_buffer的时候,也就是在tty_buffer_init函数中:
void tty_buffer_init(struct tty_struct *tty)
spin_lock_init(&tty->buf.lock);
tty->buf.head= NULL;
tty->buf.tail= NULL;
tty->buf.free= NULL;
tty->buf.memory_used= 0;
INIT_DELAYED_WORK(&tty->buf.work,flush_to_ldisc);
在函数的最后,初始化了一个工作队列。
而这个队列在什么时候调度呢,在驱动层里receive_chars的最后调用了tty_flip_buffer_push这个函数。
void tty_flip_buffer_push(struct tty_struct *tty)
unsigned long flags;spin_lock_irqsave(&tty->buf.lock, flags);if (tty->buf.tail != NULL)
tty->buf.tail->commit = tty->buf.tail->used;spin_unlock_irqrestore(&tty->buf.lock, flags);
if (tty->low_latency)
flush_to_ldisc(&tty->buf.work.work);else schedule_delayed_work(&tty->buf.work, 1);
那么,在push数据到tty_buffer的时候有两种方式,一种是flush_to_ldisc,另一种就是调度tty缓冲区的工作队列。
flush_to_ldisc是队列调用的函数:
static void flush_to_ldisc(struct work_struct *work)[!--empirenews.page--]
while((head = tty->buf.head) != NULL) {
count= head->commit – head->read;
char_buf= head->char_buf_ptr + head->read;
flag_buf= head->flag_buf_ptr + head->read;
head->read+= count;
disc->ops->receive_buf(tty,char_buf,
flag_buf,count);
这个函数主要的功能是,从tty_buffer中找到数据缓冲区char_buf_ptr,并将这个缓冲区指针传递给线路规程的操作函数receive_buf.再来看receive_buf:
static void n_tty_receive_buf(struct tty_struct *tty, const unsigned char*cp,
char *fp, int count)
if(tty->real_raw) {
memcpy(tty->read_buf+ tty->read_head, cp, i);
}else{
switch(flags) {
caseTTY_NORMAL:
n_tty_receive_char(tty,*p);
break;
if(tty->ops->flush_chars)
从上面这段代码可以看到,if条件成立,明显地是拷贝数据进tty的read_buf;进入else,在正常的状态下会调用n_tty_receive_char,然后会调用put_tty_queue,在这个函数里最终还是把数据拷贝到tty的read_buf中。
到此,tty驱动的读操作数据链路基本上连通了。
uart_write:
static int uart_write(struct tty_struct *tty,
const unsigned char *buf, int count)
port= state->uart_port;
circ= &state->xmit;
while(1){
c= CIRC_SPACE_TO_END(circ->head, circ->tail, UART_XMIT_SIZE);
memcpy(circ->buf+ circ->head, buf, c);
uart_start(tty);
return ret;
上面代码的意思是把要写的数据拷贝到state的缓冲区里。然后调用uart_start.
static void __uart_start(struct tty_struct *tty)
struct uart_state *state = tty->driver_data;
struct uart_port *port = state->uart_port;
if(!uart_circ_empty(&state->xmit) && state->xmit.buf&&
!tty->stopped && !tty->hw_stopped)
port->ops->start_tx(port);
调用了uart_port的操作函数集的start_tx.
static void serial8250_start_tx(struct uart_port *port)
struct uart_8250_port *up = container_of(port, struct uart_8250_port, port);
transmit_chars(up);
在transmit_chars中会把state->xmit缓冲区的数据写进串口发送数据寄存器,也就是数据到达硬件层。到此,写操作的数据链路也连通。
