当前位置:首页 > 单片机 > 单片机
[导读]  Today I implement "Hello World" on PIC32MZ EC starter kit. The application of "Hello World" only lights up a LED. There are three LEDs on the starter kit board -- LED1 and LED2 and LED3. At the mo
  Today I implement "Hello World" on PIC32MZ EC starter kit. The application of "Hello World" only lights up a LED. There are three LEDs on the starter kit board -- LED1 and LED2 and LED3. At the moment, I only light LED1 on RH0.
Every PIC application has to set several configuration bits, PIC32 is no exception. So we start with configuration bits. The following is the configuration bits I set for the "Hello world" application.
// PIC32MZ2048ECH144 Configuration Bit Settings
// 'C' source line config statements
#include
// DEVCFG3  BFFFFFFF
// USERID = No Setting
#pragma config FMIIEN = ON // Ethernet RMII/MII Enable (MII Enabled) // in MII Mode, you need a 25MHz XTAL, in RMII Mode, need a 50MHz Clock.
#pragma config FETHIO = ON // Ethernet I/O Pin Select (Default Ethernet I/O)
#pragma config PGL1WAY = ON // Permission Group Lock One Way Configuration (Allow only one reconfiguration)
#pragma config PMDL1WAY = ON // Peripheral Module Disable Configuration (Allow only one reconfiguration)
#pragma config IOL1WAY = ON // Peripheral Pin Select Configuration (Allow only one reconfiguration)
#pragma config FUSBIDIO = OFF // USB USBID Selection (Controlled by Port Function)
// DEVCFG2  7FF9B11A
#pragma config FPLLIDIV = DIV_3 // System PLL Input Divider (3x Divider)
#pragma config FPLLRNG = RANGE_5_10_MHZ // System PLL Input Range (5-10 MHz Input)
#pragma config FPLLICLK = PLL_POSC // System PLL Input Clock Selection (POSC is input to the System PLL)
#pragma config FPLLMULT = MUL_50 // System PLL Multiplier (PLL Multiply by 50)
#pragma config FPLLODIV = DIV_2 // System PLL Output Clock Divider (2x Divider)
#pragma config UPLLFSEL = FREQ_24MHZ // USB PLL Input Frequency Selection (USB PLL input is 24 MHz)
#pragma config UPLLEN = OFF // USB PLL Enable (USB PLL is disabled)
// DEVCFG1  7F7F3839
#pragma config FNOSC = SPLL // Oscillator Selection Bits (System PLL)
#pragma config DMTINTV = WIN_127_128 // DMT Count Window Interval (Window/Interval value is 127/128 counter value)
#pragma config FSOSCEN = OFF // Secondary Oscillator Enable (Disable SOSC)
#pragma config IESO = OFF // Internal/External Switch Over (Disabled)
#pragma config POSCMOD = EC // Primary Oscillator Configuration (External clock mode)
#pragma config OSCIOFNC = ON // CLKO Output Signal Active on the OSCO Pin (Enabled)
#pragma config FCKSM = CSDCMD // Clock Switching and Monitor Selection (Clock Switch Disabled, FSCM Disabled)
#pragma config WDTPS = PS1048576 // Watchdog Timer Postscaler (1:1048576)
#pragma config WDTSPGM = STOP // Watchdog Timer Stop During Flash Programming (WDT stops during Flash programming)
#pragma config WINDIS = NORMAL // Watchdog Timer Window Mode (Watchdog Timer is in non-Window mode)
#pragma config FWDTEN = OFF // Watchdog Timer Enable (WDT Disabled)
#pragma config FWDTWINSZ = WINSZ_25 // Watchdog Timer Window Size (Window size is 25%)
#pragma config DMTCNT = DMT31 // Deadman Timer Count Selection (2^31 (2147483648))
#pragma config FDMTEN = OFF // Deadman Timer Enable (Deadman Timer is disabled)
// DEVCFG0  FFFFFFF7
#pragma config DEBUG = OFF // Background Debugger Enable (Debugger is disabled)
#pragma config JTAGEN = ON // JTAG Enable (JTAG Port Enabled)
#pragma config ICESEL = ICS_PGx2 // ICE/ICD Comm Channel Select (Communicate on PGEC2/PGED2)
#pragma config TRCEN = ON // Trace Enable (Trace features in the CPU are enabled)
#pragma config BOOTISA = MIPS32 // Boot ISA Selection (Boot code and Exception code is MIPS32)
#pragma config FECCCON = OFF_UNLOCKED // Dynamic Flash ECC Configuration (ECC and Dynamic ECC are disabled (ECCCON bits are writable))
#pragma config FSLEEP = OFF // Flash Sleep Mode (Flash is powered down when the device is in Sleep mode)
#pragma config DBGPER = ALLOW_PG2 // Debug Mode CPU Access Permission (Allow CPU access to Permission Group 2 permission regions)
#pragma config EJTAGBEN = NORMAL // EJTAG Boot (Normal EJTAG functionality)
// DEVCP0
#pragma config CP = OFF // Code Protect (Protection Disabled)
// SEQ0
// DEVADC1
// DEVADC2
// DEVADC3
// DEVADC4
// DEVADC5
Please remember a configuration bit can only be programmed logic 0, the unprogrammed state is logic 1, and device configuration bits may vary according to hardware and software. An important point is that PLL must output between 350 and 700 MHz. The PLL output is 400MHz in my configuration. Anyway, above configuration words work to me till now.
  Configuration bits is set, then we will continue with main function. The main function is very simple, just toggle H0 to logic 1. But before we do that, we should change the direction of H0 to be output. For 8-bit PIC, we usually code that like below.
TRISHbits.TRISH0 = 0; // clear TRISH bit0, H0 to be output
PORTHbits.RH0 = 1; // set PORTH bit0
  But for PIC32, below code is recommended (use LATx to write IO, PORTx to read IO).
LATHbits.LATH0 = 0;
  Every PIC32 I/O module register has a corresponding CLR(clear), SET(set) and INV(invert) register designed to provide fast atomic bit manipulations, a value written to a SET, CLR or INV register effectively performs the implied operation, but only on the corresponding base register and only bits specified as '1' as modified. Bits specified as '0' are not modified.
  So the above implemention has alternative option
TRISHCLR = (1<<0); // TRISH bit0 clear
LATHSET = (1<<0); // LATH bit0 set '1'
It almost like
TRISH &= 0xFFFFFFFE;
LATH |= 0x00000001;
  But it performs faster and more effectively than above. So far, there is an important point not to clarify. The I/O port H0 mixes with analog feature, and the analog feature should be disabled. For this point, PIC32MZ is different than PIC32MX. On PIC32MX devices, the analog function of an I/O pin was determined by the PCFGx bit in AD1PCFG register. On PIC32MZ devices, the analog selection function has been moved into a separate register on each I/O port. Clear ANSxy (ANSELx) bit to select digital mode.
  Finally, the main code of "Hello world" is
#include
#include "ConfigurationBits.h"
//#define LED_IOCTL() TRISHbits.TRISH0 = 0
//#define LED_SETON() LATHbits.LATH0 = 1
//#define LED_OPEN() ANSELHbits.ANSH0 = 0
//#define LED_IOCTL() TRISH &= 0xFFFFFFFE
//#define LED_SETON() LATH |= 0x00000001
//#define LED_OPEN() ANSELH &= 0xFFFFFFFE
#define LED_IOCTL() TRISHCLR = (1<<0)
#define LED_SETON() LATHSET = (1<<0)
void main()
LED_OPEN();
LED_IOCTL();
LED_SETON();
while (1)
; // do nothing
特朗普集团近日取消了其新推出的T1智能手机“将在美国制造”的宣传标语,此举源于外界对这款手机能否以当前定价在美国本土生产的质疑。
关键字: 特朗普 苹果 AI
美国总统特朗普在公开场合表示,他已要求苹果公司CEO蒂姆·库克停止在印度建厂,矛头直指该公司生产多元化的计划。
关键字: 特朗普 苹果 AI
4月10日消息,据媒体报道,美国总统特朗普宣布,美国对部分贸易伙伴暂停90天执行新关税政策,同时对中国的关税提高到125%,该消息公布后苹果股价飙升了15%。这次反弹使苹果市值增加了4000多亿美元,目前苹果市值接近3万...
关键字: 特朗普 AI 人工智能 特斯拉
3月25日消息,据报道,当地时间3月20日,美国总统特朗普在社交媒体平台“真实社交”上发文写道:“那些被抓到破坏特斯拉的人,将有很大可能被判入狱长达20年,这包括资助(破坏特斯拉汽车)者,我们正在寻找你。”
1月22日消息,刚刚,新任美国总统特朗普放出重磅消息,将全力支持美国AI发展。
关键字: 特朗普 AI 人工智能
特朗普先生有两件事一定会载入史册,一个是筑墙,一个是挖坑。在美墨边境筑墙的口号确保边境安全,降低因非法移民引起的犯罪率过高问题;在中美科技产业之间挖坑的口号也是安全,美国企业不得使用对美国国家安全构成威胁的电信设备,总统...
关键字: 特朗普 孤立主义 科技产业
据路透社1月17日消息显示,知情人士透露,特朗普已通知英特尔、铠侠在内的几家华为供应商,将要撤销其对华为的出货的部分许可证,同时将拒绝其他数十个向华为供货的申请。据透露,共有4家公司的8份许可被撤销。另外,相关公司收到撤...
关键字: 华为 芯片 特朗普
曾在2018年时被美国总统特朗普称作“世界第八奇迹”的富士康集团在美国威斯康星州投资建设的LCD显示屏工厂项目,如今却因为富士康将项目大幅缩水并拒绝签订新的合同而陷入了僵局。这也导致富士康无法从当地政府那里获得约40亿美...
关键字: 特朗普 富士康
今年5月,因自己发布的推文被贴上“无确凿依据”标签而与推特发生激烈争执后,美国总统特朗普签署了一项行政令,下令要求重审《通信规范法》第230条。
关键字: 谷歌 facebook 特朗普
众所周知,寄往白宫的所有邮件在到达白宫之前都会在他地进行分类和筛选。9月19日,根据美国相关执法官员的通报,本周早些时候,执法人员截获了一个寄给特朗普总统的包裹,该包裹内包含蓖麻毒蛋白。
关键字: 美国 白宫 特朗普
