当前位置:首页 > 芯闻号 > 充电吧
[导读]题目链接:http://acm.hdu.edu.cn/showproblem.php?pid=5047 题面: Sawtooth Time Limit: 2000/1000 MS (Java/Ot
题面:
Sawtooth Time Limit: 2000/1000 MS (Java/Others)    Memory Limit: 65536/65536 K (Java/Others)
Total Submission(s): 1636    Accepted Submission(s): 637
Problem Description Think about a plane:
● One straight line can divide a plane into two regions.
● Two lines can divide a plane into at most four regions.
● Three lines can divide a plane into at most seven regions.
● And so on...
Now we have some figure constructed with two parallel rays in the same direction, joined by two straight segments. It looks like a character “M”. You are given N such “M”s. What is the maximum number of regions that these “M”s can divide a plane ?
Input The first line of the input is T (1 ≤ T ≤ 100000), which stands for the number of test cases you need to solve.
Each case contains one single non-negative integer, indicating number of “M”s. (0 ≤ N ≤ 1012)
Output For each test case, print a line “Case #t: ”(without quotes, t means the index of the test case) at the beginning. Then an integer that is the maximum number of regions N the “M” figures can divide.
Sample Input
Sample Output
Case #1: 2
Case #2: 19
Source 2014 ACM/ICPC Asia Regional Shanghai Online   解题:
    每一个M四条边,每条边最多与原来的边相交,形成原来的边数*4个交点,就多出来相应这么多的面,因为原来M内部也有一个面,故还需加一。
    所以,F(n)=F(n-1)+4*4*(n-1)+1。不断迭代可以将这条公式化成F(n)=8*n*n-7*n+1。因为数据范围很大,所以要用大数。
    直接用公式配合C++大数模板T了。于是,我用JAVA大数类交了一发,1900ms,不得不说时间卡得真紧。上网一查,原来JAVA的读入输出是能够优化的,详见这篇博客。我自己用大数交了一下800ms,不过貌似也可以在大数乘上优化。
代码(JAVA):
import java.io.*;
import java.util.*;
import java.math.*;
;public class Main {
	public static void main(String args[])
		Scanner cin = new Scanner(System.in);
        int t=cin.nextInt();
        for(int i=1;i<=t;i=i+1)
        	BigInteger ans,tmp;
        	BigInteger n=cin.nextBigInteger();
        	ans=n.multiply(n);
        	ans=ans.multiply(BigInteger.valueOf(8));
        	tmp=n.multiply(BigInteger.valueOf(7));
        	ans=ans.subtract(tmp);
        	ans=ans.add(BigInteger.ONE);
        	System.out.println("Case #"+i+": "+ans);
代码(JAVA优化版):
import java.io.*;
import java.util.*;
import java.math.*;
		Scanner sc = new Scanner(new BufferedInputStream(System.in));
		PrintWriter cout=new PrintWriter(System.out);
        int t=sc.nextInt();
        	BigInteger ans,tmp;
        	BigInteger n=sc.nextBigInteger();
        	ans=n.multiply(n);
        	cout.println("Case #"+i+": "+ans);
        cout.flush();
代码(C++大数模板):
#include
#include
#include
#include
#include
using namespace std;
#define MAXN 9999
#define MAXSIZE 10
#define DLEN 4
class BigNum
private:
	int a[500];    //可以控制大数的位数
	int len;       //大数长度
public:
	BigNum(){ len = 1;memset(a,0,sizeof(a)); }   //构造函数
	BigNum(const int);       //将一个int类型的变量转化为大数
	BigNum(const char*);     //将一个字符串类型的变量转化为大数
	BigNum(const BigNum &);  //拷贝构造函数
	BigNum &operator=(const BigNum &);   //重载赋值运算符,大数之间进行赋值运算
	friend istream& operator>>(istream&,  BigNum&);   //重载输入运算符
	friend ostream& operator<<(ostream&,  BigNum&);   //重载输出运算符
	BigNum operator+(const BigNum &) const;   //重载加法运算符,两个大数之间的相加运算
	BigNum operator-(const BigNum &) const;   //重载减法运算符,两个大数之间的相减运算
	BigNum operator*(const BigNum &) const;   //重载乘法运算符,两个大数之间的相乘运算
	BigNum operator/(const int   &) const;    //重载除法运算符,大数对一个整数进行相除运算
	BigNum operator^(const int  &) const;    //大数的n次方运算
	int    operator%(const int  &) const;    //大数对一个int类型的变量进行取模运算
	bool   operator>(const BigNum & T)const;   //大数和另一个大数的大小比较
	bool   operator>(const int & t)const;      //大数和一个int类型的变量的大小比较
	void print();       //输出大数
BigNum::BigNum(const int b)     //将一个int类型的变量转化为大数
	int c,d = b;
	len = 0;
	while(d > MAXN)
		c = d - (d / (MAXN + 1)) * (MAXN + 1);
		d = d / (MAXN + 1);
		a[len++] = c;
	a[len++] = d;
BigNum::BigNum(const char*s)     //将一个字符串类型的变量转化为大数
	int t,k,index,l,i;
	l=strlen(s);
	len=l/DLEN;
	if(l%DLEN)
		len++;
	index=0;
	for(i=l-1;i>=0;i-=DLEN)
		t=0;
		k=i-DLEN+1;
		if(k<0)
			k=0;
		for(int j=k;j<=i;j++)
			t=t*10+s[j]-'0';
		a[index++]=t;
BigNum::BigNum(const BigNum & T) : len(T.len)  //拷贝构造函数
	int i;
	for(i = 0 ; i < len ; i++)
		a[i] = T.a[i];
BigNum & BigNum::operator=(const BigNum & n)   //重载赋值运算符,大数之间进行赋值运算
	int i;
	len = n.len;
		a[i] = n.a[i];
	return *this;
istream& operator>>(istream & in,  BigNum & b)   //重载输入运算符
	char ch[MAXSIZE*4];
	int i = -1;
	in>>ch;
	int l=strlen(ch);
	int count=0,sum=0;
	for(i=l-1;i>=0;)
		sum = 0;
		int t=1;
		for(int j=0;j<4&&i>=0;j++,i--,t*=10)
			sum+=(ch[i]-'0')*t;
		b.a[count]=sum;
		count++;
	b.len =count++;
	return in;
ostream& operator<<(ostream& out,  BigNum& b)   //重载输出运算符
	int i;
	cout << b.a[b.len - 1];
	for(i = b.len - 2 ; i >= 0 ; i--)
		cout.width(DLEN);
		cout.fill('0');
		cout << b.a[i];
	return out;
BigNum BigNum::operator+(const BigNum & T) const   //两个大数之间的相加运算
	BigNum t(*this);
	int i,big;      //位数
	big = T.len > len ? T.len : len;
	for(i = 0 ; i < big ; i++)
		t.a[i] +=T.a[i];
		if(t.a[i] > MAXN)
			t.a[i + 1]++;
			t.a[i] -=MAXN+1;
	if(t.a[big] != 0)
		t.len = big + 1;
	else
		t.len = big;
	return t;
BigNum BigNum::operator-(const BigNum & T) const   //两个大数之间的相减运算
	int i,j,big;
	bool flag;
	BigNum t1,t2;
	if(*this>T)
		t1=*this;
		t2=T;
		flag=0;
	else
		t1=T;
		t2=*this;
		flag=1;
	big=t1.len;
		if(t1.a[i] < t2.a[i])
			j = i + 1;
			while(t1.a[j] == 0)
				j++;
			t1.a[j--]--;
			while(j > i)
				t1.a[j--] += MAXN;
			t1.a[i] += MAXN + 1 - t2.a[i];
		else
			t1.a[i] -= t2.a[i];
	t1.len = big;
	while(t1.a[t1.len - 1] == 0 && t1.len > 1)
		t1.len--;
		big--;
	if(flag)
		t1.a[big-1]=0-t1.a[big-1];
	return t1;
BigNum BigNum::operator*(const BigNum & T) const   //两个大数之间的相乘运算
	BigNum ret;
	int i,j,up;
	int temp,temp1;
		up = 0;
		for(j = 0 ; j < T.len ; j++)
			temp = a[i] * T.a[j] + ret.a[i + j] + up;
			if(temp > MAXN)
				temp1 = temp - temp / (MAXN + 1) * (MAXN + 1);
				up = temp / (MAXN + 1);
				ret.a[i + j] = temp1;
			else
				up = 0;
				ret.a[i + j] = temp;
		if(up != 0)
			ret.a[i + j] = up;
	ret.len = i + j;
	while(ret.a[ret.len - 1] == 0 && ret.len > 1)
		ret.len--;
	return ret;
BigNum BigNum::operator/(const int & b) const   //大数对一个整数进行相除运算
	BigNum ret;
	int i,down = 0;
	for(i = len - 1 ; i >= 0 ; i--)
		ret.a[i] = (a[i] + down * (MAXN + 1)) / b;
		down = a[i] + down * (MAXN + 1) - ret.a[i] * b;
	ret.len = len;
		ret.len--;
	return ret;
int BigNum::operator %(const int & b) const    //大数对一个int类型的变量进行取模运算
	int i,d=0;
	for (i = len-1; i>=0; i--)
		d = ((d * (MAXN+1))% b + a[i])% b;
	return d;
BigNum BigNum::operator^(const int & n) const    //大数的n次方运算
	BigNum t,ret(1);
	int i;
	if(n<0)
		exit(-1);
	if(n==0)
		return 1;
	if(n==1)
		return *this;
	int m=n;
	while(m>1)
		t=*this;
		for( i=1;i<<1<=m;i<<=1)
			t=t*t;
		m-=i;
		ret=ret*t;
		if(m==1)
			ret=ret*(*this);
	return ret;
bool BigNum::operator>(const BigNum & T) const   //大数和另一个大数的大小比较
	int ln;
	if(len > T.len)
		return true;
	else if(len == T.len)
		ln = len - 1;
		while(a[ln] == T.a[ln] && ln >= 0)
			ln--;
		if(ln >= 0 && a[ln] > T.a[ln])
			return true;
		else
			return false;
	else
		return false;
bool BigNum::operator >(const int & t) const    //大数和一个int类型的变量的大小比较
	BigNum b(t);
	return *this>b;
void BigNum::print()    //输出大数
	int i;
	cout << a[len - 1];
	for(i = len - 2 ; i >= 0 ; i--)
		cout.width(DLEN);
		cout.fill('0');
		cout << a[i];
	cout << endl;
int main(void)
	int t;
	BigNum n,ans;
    cin>>t;
	for(int i=1;i<=t;i++)
		cin>>n;
		cout<<"Case #"<
