直流伺服电动机驱动器电路
直流伺服电动机驱动器电路,DC servo motor driver
Specifications
DC Servo Motor Driver kit, designed using MC33030 IC, is the fastest and low cost way of getting your DC Servo Motor up and running.
Input - 12 VDC
Output - can drive upto 1 A Load
Overcurrent shutdown, overvoltage shutdown
Programmable reference input
Power-On LED indicator
Relimate connector for interfacing the kit
Four mounting holes of 3.2 mm each
PCB dimensions 45 mm x 54 mm
Schematic
Parts List
PCB |
