当前位置:首页 > 芯闻号 > 充电吧
[导读]Oracle数据库安装的时候会自带一个练习用数据库(其中包含employee表,后来版本中此表改名为emp); 首先在安装过程中应该有个选项“是否安装实例表”(完全安装模式下默认是选择的),需要选择才
首先在安装过程中应该有个选项“是否安装实例表”(完全安装模式下默认是选择的),需要选择才有此表;
此表归属于scott账户,scott用户默认口令为tiger
如果发现scott账户已过期(Oracle 10g中经常发生),或口令不正确,可以通过以下方法进行设置
Sql代码  --账户解锁   alter user scott account unlock;   --重设scott账户口令为tiger   alter user scott identified by tiger;
附:实例表建表语句(适用于Oracle)
Sql代码  ----------------------demobld.sql begin-----------------------   --   -- Copyright (c) Oracle Corporation 1988, 2000. All Rights Reserved.   --   -- NAME   -- demobld.sql   --   -- DESCRIPTION   -- This script. creates the SQL*Plus demonstration tables in the   -- current schema. It should be STARTed by each user wishing to   -- access the tables. To remove the tables use the demodrop.sql   -- script.   --   -- USAGE   -- From within SQL*Plus, enter:   -- START demobld.sql      SET TERMOUT ON   PROMPT Building demonstration tables. Please wait.   SET TERMOUT OFF      DROP TABLE EMP;   DROP TABLE DEPT;   DROP TABLE BONUS;   DROP TABLE SALGRADE;   DROP TABLE DUMMY;      CREATE TABLE EMP   (EMPNO NUMBER(4) NOT NULL,   ENAME VARCHAR2(10),   JOB VARCHAR2(9),   MGR NUMBER(4),   HIREDATE DATE,   SAL NUMBER(7, 2),   COMM NUMBER(7, 2),   DEPTNO NUMBER(2));      INSERT INTO EMP VALUES   (7369, 'SMITH', 'CLERK', 7902,   TO_DATE('17-DEC-1980', 'DD-MON-YYYY'), 800, NULL, 20);   INSERT INTO EMP VALUES   (7499, 'ALLEN', 'SALESMAN', 7698,   TO_DATE('20-FEB-1981', 'DD-MON-YYYY'), 1600, 300, 30);   INSERT INTO EMP VALUES   (7521, 'WARD', 'SALESMAN', 7698,   TO_DATE('22-FEB-1981', 'DD-MON-YYYY'), 1250, 500, 30);   INSERT INTO EMP VALUES   (7566, 'JONES', 'MANAGER', 7839,   TO_DATE('2-APR-1981', 'DD-MON-YYYY'), 2975, NULL, 20);   INSERT INTO EMP VALUES   (7654, 'MARTIN', 'SALESMAN', 7698,   TO_DATE('28-SEP-1981', 'DD-MON-YYYY'), 1250, 1400, 30);   INSERT INTO EMP VALUES   (7698, 'BLAKE', 'MANAGER', 7839,   TO_DATE('1-MAY-1981', 'DD-MON-YYYY'), 2850, NULL, 30);   INSERT INTO EMP VALUES   (7782, 'CLARK', 'MANAGER', 7839,   TO_DATE('9-JUN-1981', 'DD-MON-YYYY'), 2450, NULL, 10);   INSERT INTO EMP VALUES   (7788, 'SCOTT', 'ANALYST', 7566,   TO_DATE('09-DEC-1982', 'DD-MON-YYYY'), 3000, NULL, 20);   INSERT INTO EMP VALUES   (7839, 'KING', 'PRESIDENT', NULL,   TO_DATE('17-NOV-1981', 'DD-MON-YYYY'), 5000, NULL, 10);   INSERT INTO EMP VALUES   (7844, 'TURNER', 'SALESMAN', 7698,   TO_DATE('8-SEP-1981', 'DD-MON-YYYY'), 1500, 0, 30);   INSERT INTO EMP VALUES   (7876, 'ADAMS', 'CLERK', 7788,   TO_DATE('12-JAN-1983', 'DD-MON-YYYY'), 1100, NULL, 20);   INSERT INTO EMP VALUES   (7900, 'JAMES', 'CLERK', 7698,   TO_DATE('3-DEC-1981', 'DD-MON-YYYY'), 950, NULL, 30);   INSERT INTO EMP VALUES   (7902, 'FORD', 'ANALYST', 7566,   TO_DATE('3-DEC-1981', 'DD-MON-YYYY'), 3000, NULL, 20);   INSERT INTO EMP VALUES   (7934, 'MILLER', 'CLERK', 7782,   TO_DATE('23-JAN-1982', 'DD-MON-YYYY'), 1300, NULL, 10);      CREATE TABLE DEPT   (DEPTNO NUMBER(2),   DNAME VARCHAR2(14),   LOC VARCHAR2(13) );      INSERT INTO DEPT VALUES (10, 'ACCOUNTING', 'NEW YORK');   INSERT INTO DEPT VALUES (20, 'RESEARCH', 'DALLAS');   INSERT INTO DEPT VALUES (30, 'SALES', 'CHICAGO');   INSERT INTO DEPT VALUES (40, 'OPERATIONS', 'BOSTON');      CREATE TABLE BONUS   (ENAME VARCHAR2(10),   JOB VARCHAR2(9),   SAL NUMBER,   COMM NUMBER);      CREATE TABLE SALGRADE   (GRADE NUMBER,   LOSAL NUMBER,   HISAL NUMBER);      INSERT INTO SALGRADE VALUES (1, 700, 1200);   INSERT INTO SALGRADE VALUES (2, 1201, 1400);   INSERT INTO SALGRADE VALUES (3, 1401, 2000);   INSERT INTO SALGRADE VALUES (4, 2001, 3000);   INSERT INTO SALGRADE VALUES (5, 3001, 9999);      CREATE TABLE DUMMY   (DUMMY NUMBER);      INSERT INTO DUMMY VALUES (0);      COMMIT;      SET TERMOUT ON   PROMPT Demonstration table build is complete.      EXIT   -------------------demobld.sql end-----------------------
实例建表语句(适用于MySQL)
Sql代码  DROP TABLE employee;   DROP TABLE dept;   DROP TABLE bonus;   DROP TABLE salgrade;   DROP TABLE dummy;      CREATE TABLE employee   (     employeeno DECIMAL(4) NOT NULL,     ename VARCHAR(10),     job VARCHAR(9),     mgr DECIMAL(4),     hiredate DATE,     sal DECIMAL(7, 2),     comm DECIMAL(7, 2),     deptno DECIMAL(2)   );      INSERT INTO employee VALUES   (7369, 'SMITH', 'CLERK', 7902, '1980-12-17', 800, NULL, 20);   INSERT INTO employee VALUES   (7499, 'ALLEN', 'SALESMAN', 7698,'1981-2-20', 1600, 300, 30);   INSERT INTO employee VALUES   (7521, 'WARD', 'SALESMAN', 7698, '1981-2-22', 1250, 500, 30);   INSERT INTO employee VALUES   (7566, 'JONES', 'MANAGER', 7839, '1981-4-2', 2975, NULL, 20);   INSERT INTO employee VALUES   (7654, 'MARTIN', 'SALESMAN', 7698, '1981-9-28', 1250, 1400, 30);   INSERT INTO employee VALUES   (7698, 'BLAKE', 'MANAGER', 7839, '1981-5-1', 2850, NULL, 30);   INSERT INTO employee VALUES   (7782, 'CLARK', 'MANAGER', 7839, '1981-7-9', 2450, NULL, 10);   INSERT INTO employee VALUES   (7788, 'SCOTT', 'ANALYST', 7566, '1982-12-9', 3000, NULL, 20);   INSERT INTO employee VALUES   (7839, 'KING', 'PRESIDENT', NULL, '1981-11-17', 5000, NULL, 10);   INSERT INTO employee VALUES   (7844, 'TURNER', 'SALESMAN', 7698, '1981-9-8', 1500, 0, 30);   INSERT INTO employee VALUES   (7876, 'ADAMS', 'CLERK', 7788, '1983-1-12', 1100, NULL, 20);   INSERT INTO employee VALUES   (7900, 'JAMES', 'CLERK', 7698, '1981-12-3', 950, NULL, 30);   INSERT INTO employee VALUES   (7902, 'FORD', 'ANALYST', 7566, '1981-12-3', 3000, NULL, 20);   INSERT INTO employee VALUES   (7934, 'MILLER', 'CLERK', 7782, '1982-1-23', 1300, NULL, 10);      CREATE TABLE dept   (deptno DECIMAL(2),   dname VARCHAR(14),   loc VARCHAR(13) );      INSERT INTO dept VALUES (10, 'ACCOUNTING', 'NEW YORK');   INSERT INTO dept VALUES (20, 'RESEARCH', 'DALLAS');   INSERT INTO dept VALUES (30, 'SALES', 'CHICAGO');   INSERT INTO dept VALUES (40, 'OPERATIONS', 'BOSTON');      CREATE TABLE bonus   (ename VARCHAR(10),   job VARCHAR(9),   sal DECIMAL,   comm DECIMAL);      CREATE TABLE salgrade   (grade DECIMAL,   losal DECIMAL,   hisal DECIMAL);      INSERT INTO salgrade VALUES (1, 700, 1200);   INSERT INTO salgrade VALUES (2, 1201, 1400);   INSERT INTO salgrade VALUES (3, 1401, 2000);   INSERT INTO salgrade VALUES (4, 2001, 3000);   INSERT INTO salgrade VALUES (5, 3001, 9999);      CREATE TABLE dummy   (dummy DECIMAL);      INSERT INTO dummy VALUES (0);
