当前位置:首页 > 电源 > 数字电源
[导读]本文 首先介绍了PIC24H系列16 位高性能单片机主要特性,方框图,接着介绍了Microstick 开发板主要特性及其电路图。 Microstick 开发板是Microchip 公司的用来开发16位数字信号控制器(DSC)dsPIC33F 和16位MCU PIC2
Microstick 开发板是Microchip 公司的用来开发16位数字信号控制器(DSC)dsPIC33F 和16位MCU PIC24H,主要用来开发智能传感器和其它嵌入式控制应用。Microstick 开发板的成本很低,它集成了编程器/调试器,可以单独使用,也可以插入原型板进行开发,成本很低。
PIC24H系列16 位高性能单片机主要特性:
通信模块:
• 4 线SPI (最多2 个模块):
- 帧支持与简单编解码器的I/O 接口
- 支持8 位和16 位数据
- 支持所有串行时钟格式和采样模式
比较器模块:
• 带可编程输入/ 输出配置的两个模拟比较器
CMOS 闪存技术:
• 低功耗高速闪存技术
• 全静态设计
• 3.3V (±10%)工作电压
• 工业级和扩展级温度
• 低功耗
封装:
• 28 引脚SPDIP/SOIC/QFN-S
• 44 引脚TQFP/QFN
图1。PIC24HJ32GP302/304、PIC24HJ64GPX02/X04 和PIC24HJ128GPX02/X04框图
dsPIC33F 和PIC24H开发板Microstick
Microstick for dsPIC33F and PIC24H Development Board
The Microstick for dsPIC33F and PIC24H devices is designed to provide an easy to use, economical development environment for 16-bit digital signal controllers and microcontrollers. The board includes an integrated debugger/programmer, a socket for the device under test and pins that facilitate insertion into a prototyping board for extremely flexible development.
图1。dsPIC33F 和PIC24H开发板Microstick外形图[!--empirenews.page--]
The Microstick for dsPIC33F and PIC24H devices is designed to provide designers with an easy to use, economical development environment for 16-bit Digital Signal Controllers and Microcontrollers.
Microstick provides all you need to get started at a very low cost. It has an integrated programmer / debugger. It can be used stand-alone or plugged into a prototyping board for extremely flexible development. The device under test is socketed for easy change-out, and Microchip’s MPLAB Integrated Development Environment supports Microstick. It has never been more affordable to get started with Microchip 16-bit devices!
开发板Microstick主要特性:
Low Cost – Priced at $24.99 at Microchip Direct
Integrated USB programmer / debugger – No external debugger required
USB Powered – Ease of use, No external power required
Socketed dsPIC/PIC24 – Flexible, Easy device replacement
0.025” Pin headers – Enables plug-in to Breadboard with room for jumper wires
Easy access to all device signals for probing
Small size - Smaller than a stick of gum at 20 x76mm – Easily Portable
On board debug LED, Utility LED and Reset Switch
Free demo code
图3。dsPIC33F 和PIC24H开发板Microstick电路图
-CAS推出CAS IP Finder,旨在改进知识产权搜索 AI增强解决方案深化搜索功能,优化用户体验  俄亥俄州哥伦布2025年9月9日 /美通社/ --...
关键字: FINDER IP ST AI
柏林2025年9月9日 /美通社/ -- 总部位于迪拜的生活方式科技品牌ASTRAUX强势亮相2025年柏林国际电子消费品展览会(IFA),首次推出的三款原创产品引发广泛关注,成功将品牌推向绿色出行与智能生活领域的舆论焦...
关键字: ST COM AI GLOBAL
北京2025年9月5日 /美通社/ -- 近日,2025年中瑞商业大奖颁奖典礼在北京举行,SGS通标标准技术服务有限公司(以下称SGS通标)作为瑞士SGS在中国的分支机构荣获了传承奖的殊荣。SGS通标北京总经理...
关键字: 可持续发展 ST AI ABILITY
RighValor现已基于Synaptics® Astra™ SL1600系列SOC运行,提供隐私至上的实时边缘智能。 加利福尼亚州帕洛阿尔托2025年9月5日 /美通社/ -- 边缘分布式代理AI先驱企业Righ今日...
关键字: 智能家居 SYNAPTICS AI ST
借助 Supermicro 的 GPU 优化服务器,扩展人工智能基础设施,更快获得结果 大规模人工智能工厂实现训练与推理的破纪录部署 Supermicro 先进...
关键字: 人工智能 MICRO NVIDIA SUPER
马萨诸塞州剑桥2025年8月20日 /美通社/ -- 今天,晶泰科技(2228.HK)宣布与韩国领先的制药企业——韩国Dong-A ST(东亚公司)签署合作备忘录(MOU),...
关键字: 泰科 AI 机器人 ST
扩展的虚拟活动包含 9 个环节、23 家企业及 40 位演讲者,较 2024 年的 7 个环节有所增加。 专注于人工智能工作负载,包括分布式推理基础设施模型、基于...
关键字: MICRO SUPER 人工智能 AI
上海2025年7月25日 /美通社/ -- 昨日,在首届上海国际低空经济博览会现场,昂际智航与翊飞航空科技正式签署ES1000型号铁鸟及101工程实验样机飞控电子集成和试飞支持合同。此次采购合同签署标志着双方自2024年...
关键字: 运输机 飞控系统 EV ST
相比上一代英特尔(Intel)处理器,性能提升高达50% 单台系统最多可搭载4颗英特尔至强6处理器(Intel Xeon 6 Processors),合计高达344...
关键字: Intel MICRO PROCESSORS SUPER
杭州 2025年7月16日 /美通社/ -- 近日,当美国加征关税,欧美市场增长持续承压之际,米奥兰特以"会展+AI"的创新模式在越南、印尼、阿联酋三地相继启动新兴市场开拓行动。依托技术赋能与本地化...
关键字: AI 中国制造 ST 数据驱动
