当前位置:首页 > 电源 > 数字电源
[导读]</a>CODEC" title="CODEC">CODEC" title="CODEC">CODEC,具有两个24位ADC和两个DAC通路,可工作在主或从模式,模拟工作电压1.8V-3.6V,数字核电压1.5V-3.6V,数字I/O电压1.8V-3.6V,3.3V和48kHz的DAC SNR为100dB(A加权),TH
</a>CODEC" title="CODEC">CODEC" title="CODEC">CODEC,具有两个24位ADC和两个DAC通路,可工作在主或从模式,模拟工作电压1.8V-3.6V,数字核电压1.5V-3.6V,数字I/O电压1.8V-3.6V,3.3V和48kHz的DAC SNR为100dB(A加权),THD为-80dB而ADC的SNR为100dB(A加权),THD为-80dB,主要用在手机,MP3播放器,,手提游戏机,手持电子设备和教育玩具.本文介绍了SSM2603主要特性, 方框图, 典型应用电路图以及音频CODEC评估板EVAL-SSM2603主要特性,电路图,材料清单和PCB布局图.
The SSM2603 is a low power, high quality stereo audio codec for portable digital audio applications with one set of stereo programmable gain amplifier (PGA) line inputs and one monaural microphone input. It features two 24-bit analog-to- digital converter (ADC) channels and two 24-bit digital-to- analog (DAC) converter channels. The SSM2603 can operate as a master or a slave. It supports various master clock frequencies, including 12 MHz or 24 MHz for USB devices; standard 256 fS or 384 fS based rates, such as 12.288 MHz and 24.576 MHz; and many common audio sampling rates, such as 96 kHz, 88.2 kHz, 48 kHz, 44.1 kHz, 32 kHz, 24 kHz, 22.05 kHz, 16 kHz, 12 kHz, 11.025 kHz, and 8 kHz. The SSM2603 can operate at power supplies as low as 1.8 V for the analog circuitry and as low as 1.5 V for the digital circuitry. The maximum voltage supply is 3.6 V for all supplies. The SSM2603 software-programmable stereo output options provide the user with many application possibilities. Its volume control functions provide a large range of gain control of the audio signal. The SSM2603 is specified over the industrial temperature range of −40℃ to +85℃. It is available in a 28-lead, 5 mm × 5 mm lead frame chip scale package (LFCSP).
The SSM2603 is a low power, high quality stereo audio codec for portable digital audio applications with one set of stereo programmable gain amplifier (PGA) line inputs and one monaural microphone input. The board can operate as a master or slave and supports various clock frequencies. The SSM2603 software-programmable stereo output options provide many application possibilities because the device can be used as a headphone driver or as a speaker driver. Its volume control functions pro-vide a large range of gain control of the audio signal. Included in this data sheet is a detailed setup and user guide for the SSM2603 evaluation board hardware and software. Read the Evaluation Board Quick Setup section to ensure that proper communi-cation is established from the host PC to the SSM2603 evaluation board.
This data sheet describes how to configure and use the SSM2603 evaluation board. It is recommended that the SSM2603 evaluation board data sheet be read in conjunction with the SSM2603 data sheet, which provides more detailed information about the specifications, internal block diagrams, and application guid-ance for the codec IC.
The SSM2603 evaluation board carries a complete application circuit for the SSM2603. The board features a USB connection to a host PC. This serves as the power supply, digital audio data, and control/status data link, making it a plug-and-play USB audio device that can communicate with the software under the Microsoft® Windows® operating system. The board also has a general-purpose 2.54 mm pitch connector to connect to an external DSP/MCU for digital audio signals.
评估板EVAL-SSM2603主要特性:
USB connectivity to host PC
External connectivity to DSP/MCU for digital audio signals (available through general-purpose 2.54 mm pitch connector)
4 audio jacks: stereo line input, mono microphone input, stereo line output, and stereo headphone output
Multiple test points across the board for monitoring signals
特朗普集团近日取消了其新推出的T1智能手机“将在美国制造”的宣传标语,此举源于外界对这款手机能否以当前定价在美国本土生产的质疑。
关键字: 特朗普 苹果 AI
美国总统特朗普在公开场合表示,他已要求苹果公司CEO蒂姆·库克停止在印度建厂,矛头直指该公司生产多元化的计划。
关键字: 特朗普 苹果 AI
4月10日消息,据媒体报道,美国总统特朗普宣布,美国对部分贸易伙伴暂停90天执行新关税政策,同时对中国的关税提高到125%,该消息公布后苹果股价飙升了15%。这次反弹使苹果市值增加了4000多亿美元,目前苹果市值接近3万...
关键字: 特朗普 AI 人工智能 特斯拉
3月25日消息,据报道,当地时间3月20日,美国总统特朗普在社交媒体平台“真实社交”上发文写道:“那些被抓到破坏特斯拉的人,将有很大可能被判入狱长达20年,这包括资助(破坏特斯拉汽车)者,我们正在寻找你。”
1月22日消息,刚刚,新任美国总统特朗普放出重磅消息,将全力支持美国AI发展。
关键字: 特朗普 AI 人工智能
特朗普先生有两件事一定会载入史册,一个是筑墙,一个是挖坑。在美墨边境筑墙的口号确保边境安全,降低因非法移民引起的犯罪率过高问题;在中美科技产业之间挖坑的口号也是安全,美国企业不得使用对美国国家安全构成威胁的电信设备,总统...
关键字: 特朗普 孤立主义 科技产业
据路透社1月17日消息显示,知情人士透露,特朗普已通知英特尔、铠侠在内的几家华为供应商,将要撤销其对华为的出货的部分许可证,同时将拒绝其他数十个向华为供货的申请。据透露,共有4家公司的8份许可被撤销。另外,相关公司收到撤...
关键字: 华为 芯片 特朗普
曾在2018年时被美国总统特朗普称作“世界第八奇迹”的富士康集团在美国威斯康星州投资建设的LCD显示屏工厂项目,如今却因为富士康将项目大幅缩水并拒绝签订新的合同而陷入了僵局。这也导致富士康无法从当地政府那里获得约40亿美...
关键字: 特朗普 富士康
今年5月,因自己发布的推文被贴上“无确凿依据”标签而与推特发生激烈争执后,美国总统特朗普签署了一项行政令,下令要求重审《通信规范法》第230条。
关键字: 谷歌 facebook 特朗普
众所周知,寄往白宫的所有邮件在到达白宫之前都会在他地进行分类和筛选。9月19日,根据美国相关执法官员的通报,本周早些时候,执法人员截获了一个寄给特朗普总统的包裹,该包裹内包含蓖麻毒蛋白。
关键字: 美国 白宫 特朗普
