当前位置:首页 > 电源 > 数字电源
[导读]Insulin pumps provide freedom and flexibility to those people who require a daily supplement of insulin to control their blood glucose levels. Todays insulin pumps are pager-sized devices worn on a be
Insulin pumps provide freedom and flexibility to those people who require a daily supplement of insulin to control their blood glucose levels. Todays insulin pumps are pager-sized devices worn on a belt that releases insulin periodically to the patient throughout the day, depending on the setting determined by the patient. Nationals small packaging and reliable, efficient power management meet the requirement these portable units have for operating over long periods of time without changing batteries.
Component Highlights
* DC/DC - High efficiency, keeps system power dissipation low, perfect for battery-powered devices.
* Microcontroller - RISC core with on-chip SRAM and Flash memory provides high computing bandwidth, and additional integration gives high I/O bandwidth and system expandability
1 Power
LP3883ES-1.2
LP3883ES-1.5
LP3883ES-1.8
2 Microcontroller
USB 1.1 Interface:
CP3UB17 - Reprogrammable Connectivity Processor with USB Interface
CP3UB26 - Reprogrammable Connectivity Processor with USB and CAN Interfaces
CAN 2.0B Active Interface:
CP3CN17 - Reprogrammable Connectivity Processor with CAN Interface
CP3CN23 - Reprogrammable Connectivity Processor with Dual CAN Interfaces
Bluetooth Baseband Processor:
NEW! CP3SP33 - Connectivity Processor with Cache, DSP, and Bluetooth, USB, and Dual CAN Interfaces
CP3BT10 - Reprogrammable Connectivity Processor with Bluetooth and USB Interfaces
CP3BT13 - Reprogrammable Connectivity Processor with Bluetooth and CAN Interfaces
CP3BT23 - Reprogrammable Connectivity Processor with Bluetooth and Dual CAN Interfaces
CP3BT26 - Reprogrammable Connectivity Processor with Bluetooth, USB, and CAN Interfaces
3 Audio Amp
LM4820ITP-6
LM4820ITPX-6
LM4864LD
4 LED Drivers
LM2623ALD
LM2623ALDX
LM2623AMM
更多医疗电子信息请关注:21ic医疗电子频道
