当前位置:首页 > 电源 > 数字电源
[导读] //////////////////////////////////////////////////////////////////  #include "stdafx.h"  #include   #include   #include "Iphlpapi.h"  using namespace std;  PIP_ADAPTER_INFO pinfo=NULL;
  #include "stdafx.h"
  #include
  #include
  unsigned long len=0;
  CString macaddress;
  CString  description;
  CString  type;
  CString  subnet;
  CString  IpAddress;
  CString  gateway;
  CString  PrimaryWinsServer;
  CString  dhcp;
  void GetInfo();
  void ParseData();
  void OutPut(CString str);
  void main()
  cout<<"------------------------网卡信息检测---------------------n";
  GetInfo();
  void GetInfo()
  if (pinfo!=NULL)
  delete (pinfo);
  unsigned long nError;
  nError  =  GetAdaptersInfo(pinfo,&len); //1??üoˉêy
  if (nError==0)
  ParseData();
  if (nError==ERROR_NO_DATA)
  OutPut("没有网络设备信息");
  if (nError==ERROR_NOT_SUPPORTED)
  OutPut("GetAdaptersInfo不支持本系统");
  if (nError==ERROR_BUFFER_OVERFLOW)
  pinfo= (PIP_ADAPTER_INFO)malloc(len);
  if (nError==0)
  ParseData();
  return;
  void ParseData()
  if (pinfo!=NULL)
  macaddress.Format("%02X:%02X:%02X:%02X:%02X:%02X",pinfo->Address[0],pinfo->Address[1],pinfo->Address[2],pinfo->Address[3],pinfo->Address[4],pinfo->Address[5]);
  description  =  pinfo->Description;
  type.Format("%d",pinfo->Type);
  PIP_ADDR_STRING pAddressList = &(pinfo->IpAddressList);
  IpAddress  ="";
  do
  IpAddress  +=  pAddressList->IpAddress.String;
  pAddressList = pAddressList->Next;
  if (pAddressList != NULL)
  IpAddress  +="rn";
  } while (pAddressList != NULL);
  subnet.Format("%s",pinfo->IpAddressList.IpMask.String);
  gateway.Format("%s",pinfo->GatewayList.IpAddress.String);
  if (pinfo->HaveWins)
  PrimaryWinsServer.Format("%s",pinfo->PrimaryWinsServer.IpAddress.String );
  else
  PrimaryWinsServer.Format("%s","N/A" );
  if (pinfo->DhcpEnabled )
  dhcp.Format("%s",pinfo->DhcpServer.IpAddress.String );
  else
  dhcp.Format("%s","N/A");
  pinfo = pinfo->Next;
  OutPut("网络设备为:t"+description);
  OutPut("Mac地址为:t"+macaddress);
  OutPut("网卡类型:t"+type);
  OutPut("IP地址:t"+IpAddress);
  OutPut("子网掩码:t"+subnet);
  OutPut("网关:t"+gateway);
  OutPut("主Wins服务器:t"+PrimaryWinsServer);
  OutPut("dhcp服务器:t"+dhcp);
  cout<
LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: 驱动电源
在工业自动化蓬勃发展的当下,工业电机作为核心动力设备,其驱动电源的性能直接关系到整个系统的稳定性和可靠性。其中,反电动势抑制与过流保护是驱动电源设计中至关重要的两个环节,集成化方案的设计成为提升电机驱动性能的关键。
关键字: 工业电机 驱动电源
LED 驱动电源作为 LED 照明系统的 “心脏”,其稳定性直接决定了整个照明设备的使用寿命。然而,在实际应用中,LED 驱动电源易损坏的问题却十分常见,不仅增加了维护成本,还影响了用户体验。要解决这一问题,需从设计、生...
关键字: 驱动电源 照明系统 散热
根据LED驱动电源的公式,电感内电流波动大小和电感值成反比,输出纹波和输出电容值成反比。所以加大电感值和输出电容值可以减小纹波。
关键字: LED 设计 驱动电源
电动汽车(EV)作为新能源汽车的重要代表,正逐渐成为全球汽车产业的重要发展方向。电动汽车的核心技术之一是电机驱动控制系统,而绝缘栅双极型晶体管(IGBT)作为电机驱动系统中的关键元件,其性能直接影响到电动汽车的动力性能和...
关键字: 电动汽车 新能源 驱动电源
在现代城市建设中,街道及停车场照明作为基础设施的重要组成部分,其质量和效率直接关系到城市的公共安全、居民生活质量和能源利用效率。随着科技的进步,高亮度白光发光二极管(LED)因其独特的优势逐渐取代传统光源,成为大功率区域...
关键字: 发光二极管 驱动电源 LED
LED通用照明设计工程师会遇到许多挑战,如功率密度、功率因数校正(PFC)、空间受限和可靠性等。
关键字: LED 驱动电源 功率因数校正
在LED照明技术日益普及的今天,LED驱动电源的电磁干扰(EMI)问题成为了一个不可忽视的挑战。电磁干扰不仅会影响LED灯具的正常工作,还可能对周围电子设备造成不利影响,甚至引发系统故障。因此,采取有效的硬件措施来解决L...
关键字: LED照明技术 电磁干扰 驱动电源
开关电源具有效率高的特性,而且开关电源的变压器体积比串联稳压型电源的要小得多,电源电路比较整洁,整机重量也有所下降,所以,现在的LED驱动电源
关键字: LED 驱动电源 开关电源
LED驱动电源是把电源供应转换为特定的电压电流以驱动LED发光的电压转换器,通常情况下:LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: LED 隧道灯 驱动电源
