YII框架学习 第五天(1) widget model 修改数据 删除数据
时间:2019-07-08 12:31:01
[导读] public function actionUpdate($id)
$goods_model = Goods::model();
$goods_info = $goods_model->findByPk($id);
if(isset($_POST['Goods']))
foreach($_POST['Goods'] as $k => $v)
$goods_info->$k = $v;
//$goods_info->goods_create_time = time();
if($goods_info->save())
$this->redirect('index.php?r=background/goods/show');
$this->renderPartial('update',array('goods_model'=>$goods_info));
}代码看着和昨天差不多,添加数据 也用的save方法
add -----> $goods_model = new Goods;
update -------> $goods_model = Goods::model();
删除数据
public function actionDel($id)
$goods_info = $goods_model->findByPk($id); // 一看就知道
if($goods_info->delete())
var_dump($goods_info);
