当前位置:首页 > 芯闻号 > 充电吧
[导读]load->model('test_model'); $count = $this->test_model->count(); $config['total_rows']
			$config['total_rows'] = $count;
			$config['per_page'] = 5;
			$config['num_links'] = 3;
			$config['base_url'] ='/ci/index.php/pagetest/index';
			$this->load->library('pagination');
			$this->pagination->initialize($config);
			echo $this->pagination->create_links();
			var_dump($this->test_model->selectLimit($id,$config['per_page']));
model:
		public function selectLimit($start,$end)
			$this->db->select('*');
			$this->db->order_by('id');
			$this->db->limit($end,$start); //注意哦
			// 生成: LIMIT $start, $end (仅限MySQL中。其它数据库有稍微不同的语法)
			$query = $this->db->get('test');
			return $query->result();
