SQL对记录结果进行按日汇总并支持分页,无记录填充0值
数据库中的格式如下,是个记录明细表,要求对明细表进行按日汇总倒序输出。
用下面的SQL语句可以进行按日汇总并且可以分页输出
DECLARE @Days TABLE ( 日期 DATETIME ) DECLARE @StartDate datetime='2014-04-05 14:22:20'--汇总的开始日期 DECLARE @EndDate datetime='2015-04-08 15:21:33'--汇总的结束日期 DECLARE @start DATETIME DECLARE @E2_UserName varchar(100)='CN000001'--用户名 DECLARE @StartID INT=1--分页使用的获取记录的开始ID DECLARE @EndID INT =15--分页使用的获取记录的结束ID,测试为15条数据 SET @start = CONVERT(VARCHAR, @StartDate, 23 )+' 00:00:00' WHILE @start <= CONVERT(VARCHAR, @EndDate, 23 )+' 00:00:00' BEGIN INSERT INTO @Days VALUES(@start) SET @start = DATEADD(DAY, 1, @start) END; WITH orderList AS ( SELECT ROW_NUMBER() OVER (ORDER BY 日期 DESC)AS Row,--这里规定了是按日期倒序排列 SUM(MD_TuiJianJiang) AS 'MD_TuiJianJiang', SUM(MD_JianDianJiang) AS 'MD_JianDianJiang', SUM(MD_RiFenHong) AS 'MD_RiFenHong', SUM(MD_JiHuo) AS 'MD_JiHuo', SUM(MD_TGZXJiang) AS 'MD_TGZXJiang', SUM(MD_LingDaoJiang) AS 'MD_LingDaoJiang', SUM(MD_ShiChangJiang) AS 'MD_ShiChangJiang', SUM(MD_Help) AS 'MD_Help', SUM(MD_Luckly) AS 'MD_Luckly', SUM(MD_FanBuJiang) AS 'MD_FanBuJiang', SUM(MD_Month) AS 'MD_Month', SUM(MD_CheckIN) AS 'MD_CheckIN', SUM(TOTAL) AS 'TOTAL', 日期 FROM ( SELECT SUM(ISNULL([MD_TuiJianJiang],0)) AS 'MD_TuiJianJiang', SUM(ISNULL([MD_JianDianJiang],0)) AS 'MD_JianDianJiang', SUM(ISNULL([MD_RiFenHong],0)) AS 'MD_RiFenHong', SUM(ISNULL([MD_JiHuo],0)) AS 'MD_JiHuo', SUM(ISNULL([MD_TGZXJiang],0)) AS 'MD_TGZXJiang', SUM(ISNULL([MD_LingDaoJiang],0)) AS 'MD_LingDaoJiang', SUM(ISNULL([MD_ShiChangJiang],0)) AS 'MD_ShiChangJiang', SUM(ISNULL([MD_Help],0)) AS 'MD_Help', SUM(ISNULL([MD_Luckly],0)) AS 'MD_Luckly', SUM(ISNULL([MD_FanBuJiang],0)) AS 'MD_FanBuJiang', SUM(ISNULL([MD_Month],0)) AS 'MD_Month', SUM(ISNULL([MD_CheckIN],0)) AS 'MD_CheckIN', SUM(ISNULL(MD_TuiJianJiang+MD_RiFenHong+MD_JianDianJiang+MD_JiHuo,0)) AS 'TOTAL', --ISNULL(DAY(MD_Datetime),DAY(B.日期)) AS 'MD_Datetime', ISNULL([E2_UserName],@E2_UserName) AS 'E2_UserName', B.日期 FROM [E2_MoneyDetails] RIGHT JOIN @Days B ON CONVERT(VARCHAR, MD_Datetime, 23 )+' 00:00:00'=B.日期 AND [E2_UserName]=@E2_UserName WHERE B.日期 BETWEEN DATEADD(DAY, -1, @StartDate) AND @EndDate GROUP BY B.日期,E2_UserName ) E GROUP BY 日期 ) SELECT * FROM orderlist WHERE Row BETWEEN @StartID AND @EndID
最终的结果样式为
