当前位置:首页 > 电源 > 数字电源
[导读]ST 公司的STA350BW是 2x50W 2.1通路数字音频系统,集成了数字音频处理,数字放大器控制和FFX功率输出级。输入电压5V-26V,四路输出配置,25V时能向6欧姆提供2x50W输出功率,100dB SNR和动态范围,输入取样速率在32kH
ST 公司的STA350BW是 2x50W 2.1通路数字音频系统,集成了数字音频处理,数字放大器控制和FFX功率输出级。输入电压5V-26V,四路输出配置,25V时能向6欧姆提供2x50W输出功率,100dB SNR和动态范围,输入取样速率在32kHz到192kHz间选择,I2C控制,数字控制增益从+42dB到-80dB,每步分辨率0.125dB。本文介绍了STA350BW主要特性,方框图,单声道并行BTL电路图,电源电路图,立体声BTL模式输出配置图以及STA350BW 2.0通路演示板电路替,输出滤波器电路图和材料清单。
STA350BW:Sound Terminal® 2.1-channel high-efficiency digital audio system
The STA350BW is an integrated solution of digital audio processing, digital amplifier control, and FFX-power output stage, thereby creating a high-power single-chip FFX® solution comprising high-quality, high-efficiency, and all-digital amplification.
The STA350BW is based on an FFX (fully flexible amplification) processor, a proprietary technology from STMicroelectronics. FFX is the evolution and the enlargement of ST’s ternary technology: the new processor can be configured to work in ternary, binary, binary differential and phase-shift PWM modulation schemes.
The STA350BW contains the ternary, binary and binary differential implementations, a subset of the full capability of the FFX processor.
The STA350BW is part of the Sound Terminal® family that provides full digital audio streaming to the speaker, offering cost effectiveness, low power dissipation and sound enrichment.
The STA350BW power section consists of four independent half-bridges. These can be configured via digital control to operate in different modes. 2.1 channels can be provided by two half-bridges and a single full-bridge, providing up to 2 x 18 W + 1 x 40 W of music output power, by using standard 4 and 8ohm speakers. Two channels can be provided by two fullbridges, providing up to 2 x 50 W of music power, by using standard 6ohm speaker or 2 x 40 W by using 8ohm speakers at 25 V. The IC can also be configured as 2.1 channels with 2 x 40 W provided by the device and external power for FFX power drive. If configured as Mono-BTL, the latter is capable of providing up to 1 x 90 W on a standard 3 ohm load or 1 x 75 W by using a 4ohm setting the supply voltage at 25 V. Please refer to the package thermal characteristics and application suggestions for more details.
Also provided in the STA350BW are a full assortment of digital processing features. This includes up to 8 programmable biquads (EQ) per channel. Special digital signal processing techniques are available in order to manage low-frequency quantization noise in case of very low frequency cutoff filter thresholds. The coefficient range -4..4 allows the easy implementation of high shelf filters. Available presets allow the advantage of earlier time-tomarket by substantially reducing the amount of software development needed for certain functions. This includes audio preset volume loudness, preset volume curves and preset EQ settings. There are also new advanced AM radio interference reduction modes. Dual-band DRC dynamically equalizes the system to provide speaker linear frequency response regardless of output power level. This feature independently processes the two bands, controlling dynamically the output power level in each band and so providing better sound clarity.
The serial audio data input interface accepts all possible formats, including the popular I2S format. Three channels of FFX processing are provided. This high-quality conversion from PCM audio to FFX PWM switching waveform provides over 100 dB SNR and dynamic range.
STA350BW主要特性:
■ Wide-range supply voltage
– 5 V to 26 V (operating range)
– 30 V (absolute maximum rating)
■ Four power output configurations(a)
– 2 channels of ternary PWM (stereo mode) (2 x 50 W into 6 ohm at 25 V)
– 3 channels - left, right using binary and LFE using ternary PWM (2.1 mode) (2 x 18 W + 1 x 40W into 2 x 4 ohm , 1 x 8 ohmat 25 V)
– 2 channels of ternary PWM (2 x 50 W) + stereo lineout ternary
– 1 channel of ternary PWM as Mono BTL (1 x 90 W into 3 ohmat 24.5V)
■ FFX®100 dB SNR and Dynamic Range
■ Selectable 32 to 192 kHz input sample rates
■ I2C control with selectable device address
■ Digital gain/attenuation +42 dB to -80 dB with 0.125 dB/step resolution
■ Soft-volume update with programmable ratio
■ Individual channel and master gain/attenuation
■Two independent DRCs configurable as a dual-band anti-clipper (B2DRC) or independent limiters/compressors
■ EQ-DRC for DRC based on filtered signals
■ Dedicated LFE processing for bass boosting with 0.125 dB/step resolution
■ Audio presets:
– 15 preset crossover filters
– 5 preset anti-clipping modes
[!--empirenews.page--]
– Preset nighttime listening mode
■ Individual channel and master soft/hard mute
■ Independent channel volume and DSP bypass
■ Automatic zero-detect mute
■ Automatic invalid input-detect mute
■ I2S input data interface
■ Input and output channel mapping
■ Up to 8 user-programmable biquads per channel
■ 3 coefficient banks for EQ presets storing with fast recall via I2C interface
■ Extended coefficient dynamic up to -4..4 for easy implementation of high shelf filters
■ Bass/treble tones and de-emphasis control
■ Selectable high-pass filter for DC blocking
■ Advanced AM interference frequency switching and noise suppression modes
■ Selectable high- or low-bandwidth noise-shaping topologies
■ Selectable clock input ratio
■ 96 kHz internal processing sample rate with quantization error noise shaping for very low cutoff frequency filters
■ Thermal overload and short-circuit protection embedded
■ Video apps: 576 x Fs input mode supported
■ Fully compatible with STA339BW and STA339BWS
图1。STA350BW方框图
图2。STA350BW单声道并行BTL电路图
图3。STA350BW电源电路图
图4。STA350BW立体声BTL模式输出配置图
STA350BW 2.0通路演示板
The STA350BW demonstration board is specifically configured for 2.0 BTL channels,releasing up to 2 x 50 W into 6 ohm of power output at 25 V of supply voltage using reduced components. It is a complete solution for the digital audio power amplifier.
图5。STA350BW 2.0通路演示板外形图
图6。STA350BW 测试连接框图
图7。STA350BW 2.0通路演示板电路图
图8。STA350BW 输出滤波器电路图
STA350BW 2.0通路演示板材料清单(BOM):
LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: 驱动电源
在工业自动化蓬勃发展的当下,工业电机作为核心动力设备,其驱动电源的性能直接关系到整个系统的稳定性和可靠性。其中,反电动势抑制与过流保护是驱动电源设计中至关重要的两个环节,集成化方案的设计成为提升电机驱动性能的关键。
关键字: 工业电机 驱动电源
LED 驱动电源作为 LED 照明系统的 “心脏”,其稳定性直接决定了整个照明设备的使用寿命。然而,在实际应用中,LED 驱动电源易损坏的问题却十分常见,不仅增加了维护成本,还影响了用户体验。要解决这一问题,需从设计、生...
关键字: 驱动电源 照明系统 散热
根据LED驱动电源的公式,电感内电流波动大小和电感值成反比,输出纹波和输出电容值成反比。所以加大电感值和输出电容值可以减小纹波。
关键字: LED 设计 驱动电源
电动汽车(EV)作为新能源汽车的重要代表,正逐渐成为全球汽车产业的重要发展方向。电动汽车的核心技术之一是电机驱动控制系统,而绝缘栅双极型晶体管(IGBT)作为电机驱动系统中的关键元件,其性能直接影响到电动汽车的动力性能和...
关键字: 电动汽车 新能源 驱动电源
在现代城市建设中,街道及停车场照明作为基础设施的重要组成部分,其质量和效率直接关系到城市的公共安全、居民生活质量和能源利用效率。随着科技的进步,高亮度白光发光二极管(LED)因其独特的优势逐渐取代传统光源,成为大功率区域...
关键字: 发光二极管 驱动电源 LED
LED通用照明设计工程师会遇到许多挑战,如功率密度、功率因数校正(PFC)、空间受限和可靠性等。
关键字: LED 驱动电源 功率因数校正
在LED照明技术日益普及的今天,LED驱动电源的电磁干扰(EMI)问题成为了一个不可忽视的挑战。电磁干扰不仅会影响LED灯具的正常工作,还可能对周围电子设备造成不利影响,甚至引发系统故障。因此,采取有效的硬件措施来解决L...
关键字: LED照明技术 电磁干扰 驱动电源
开关电源具有效率高的特性,而且开关电源的变压器体积比串联稳压型电源的要小得多,电源电路比较整洁,整机重量也有所下降,所以,现在的LED驱动电源
关键字: LED 驱动电源 开关电源
LED驱动电源是把电源供应转换为特定的电压电流以驱动LED发光的电压转换器,通常情况下:LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: LED 隧道灯 驱动电源
