调试JDK源码-ConcurrentHashMap实现原理
调试JDK源码-一步一步看HashMap怎么Hash和扩容
调试JDK源码-HashSet实现原理
调试JDK源码-调试JDK源码-Hashtable实现原理以及线程安全的原因
ConcurrentHashMap线程安全的总结是我从源码分析出来的:
ConcurrentHashMap所谓线程安全是如果没有哈希冲突使用compareAndSwapObject方式新增节点,如果哈希冲突的时候锁住哈希冲突的节点,这样新增的节点是线程安全的,而 ConcurrentHashMap又不像hashtable那样整个put方法被锁定,所以性能比hashtable要好,因为这样不影响其他节点的插入和读取。
具体看下面完整的分析过程就知道了。
Mapcm = new ConcurrentHashMap(); for (int i = 0; i < 20; i++) { cm.put((char) (i + 65) + (char) (i + 66) + (char) (i + 67) + "", i + ">>>http://blog.csdn.net/unix21/"); }
注释写的很清楚
/* ---------------- Public operations -------------- */ /** * Creates a new, empty map with the default initial table size (16). */ public ConcurrentHashMap() { }
再到
public abstract class AbstractMapimplements Map{ /** * Sole constructor. (For invocation by subclass constructors, typically * implicit.) */ protected AbstractMap() { } // Query Operations /** * {@inheritDoc} * * @implSpec * This implementation returns entrySet().size(). */ public int size() { return entrySet().size(); }
第一次put
下面是完整的
/** Implementation for put and putIfAbsent */ final V putVal(K key, V value, boolean onlyIfAbsent) { if (key == null || value == null) throw new NullPointerException(); int hash = spread(key.hashCode()); int binCount = 0; for (Node[] tab = table;;) { Nodef; int n, i, fh; if (tab == null || (n = tab.length) == 0) tab = initTable(); else if ((f = tabAt(tab, i = (n - 1) & hash)) == null) { if (casTabAt(tab, i, null, new Node(hash, key, value, null))) break; // no lock when adding to empty bin } else if ((fh = f.hash) == MOVED) tab = helpTransfer(tab, f); else { V oldVal = null; synchronized (f) { if (tabAt(tab, i) == f) { if (fh >= 0) { binCount = 1; for (Nodee = f;; ++binCount) { K ek; if (e.hash == hash && ((ek = e.key) == key || (ek != null && key.equals(ek)))) { oldVal = e.val; if (!onlyIfAbsent) e.val = value; break; } Nodepred = e; if ((e = e.next) == null) { pred.next = new Node(hash, key, value, null); break; } } } else if (f instanceof TreeBin) { Nodep; binCount = 2; if ((p = ((TreeBin)f).putTreeVal(hash, key, value)) != null) { oldVal = p.val; if (!onlyIfAbsent) p.val = value; } } } } if (binCount != 0) { if (binCount >= TREEIFY_THRESHOLD) treeifyBin(tab, i); if (oldVal != null) return oldVal; break; } } } addCount(1L, binCount); return null; }
可以看出ConcurrentHashMap不是像hashTable一样整个put方法synchronized
initTable()
Thread.yield(); // lost initialization race; just spin
U.compareAndSwapInt
compareAndSwapInt() 是sun.misc.Unsafe类中的一个本地方法。
对此,我们需要了解的是 compareAndSetState(expect, update) 是以原子的方式操作当前线程;若当前线程的状态为expect,则设置它的状态为update。
下一步
回到putVal
下一步
这次无需初始化了
进入casTabAt,又用到了U.compareAndSwapObject完成新节点的插入
关于CAS https://en.wikipedia.org/wiki/Compare-and-swap
C语言实现
int compare_and_swap(int* reg, int oldval, int newval) { ATOMIC(); int old_reg_val = *reg; if (old_reg_val == oldval) *reg = newval; END_ATOMIC(); return old_reg_val; }
要实现无锁(lock-free)的非阻塞算法有多种实现方法,其中CAS(比较与交换,Compare and swap)是一种有名的无锁算法。
CAS, CPU指令,在大多数处理器架构,包括IA32、Space中采用的都是CAS指令,CAS的语义是“我认为V的值应该为A,如果是,那么将V的值更新为B,否则不修改并告诉V的值实际为多少”,
CAS是项乐观锁技术,当多个线程尝试使用CAS同时更新同一个变量时,只有其中一个线程能更新变量的值,而其它线程都失败,失败的线程并不会被挂起,而是被告知这次竞争中失败,并可以再次尝试。
CAS有3个操作数,内存值V,旧的预期值A,要修改的新值B。当且仅当预期值A和内存值V相同时,将内存值V修改为B,否则什么都不做。
参考:非阻塞同步算法与CAS(Compare and Swap)无锁算法
回到putval
和hashmap和hashtable一样,ConcurrentHashMap内部也是有一个静态嵌套类实现节点的
static class Nodeimplements Map.Entry{ final int hash; final K key; volatile V val; volatile Nodenext; Node(int hash, K key, V val, Nodenext) { this.hash = hash; this.key = key; this.val = val; this.next = next; }
下一步
至此完成第一次put
第二次put
又调用casTabAt(tab, i, null,
new Node
第2个节点插入完成
下一步
下一步
下一步
下一步
下一步
下一步
至此完成第二次put
第三次put
下一步,i=6 f=tabat(6) =null,这样就在这个索引插值
下一步
下一步
第三次put完成
经过几次put都和第三步一样,第11次put又进入到synchronized (f)代码块,
因为这次i=0,而f=tab[0]不为null
从上面的代码可以看到f被锁定
下一步,e=f pred=e,新节点插
下一步,看出新节点插在之前节点的next后面
总结:这样就看出ConcurrentHashMap可以保证哈希冲突的时候新增节点的线程安全性
