当前位置:首页 > > 充电吧
[导读]<?php // 账号登录验证 function tableIsExits($tablesName, $findtablename) {     $result = mysql_query("S
<?php
// 账号登录验证
    $result = mysql_query("SHOW TABLES FROM $tablesName");
    $i = mysql_num_rows($result);
    if ($i < 1) {
        return false;
    for ($x = 0; $x < $i; $x ++) {
        $ret = mysql_table_name($result, $x);
        if ($ret == $findtablename) {
            return true;
    return false;
// 选则表单
class zhClass
    public $zh;
    // 账号
    public $mm;
    // 密码
    public $con;
    // 数据库句柄
    public function checkZh() // 检测账号是否存在
        $result = mysql_query("SELECT * FROM teacher WHERE id=$this->zh");
        if (mysql_num_rows($result) != 0) {
            return true;
        } else {
            return false;
    public function __construct() // 构造函数 连接到数据库 打开账号数据表
        $this->con = mysql_connect("localhost", "root", "root");
        mysql_query("set names 'utf8'");
        if (! $this->con) {
            die('连接服务器失败: ' . mysql_error());
        } else {
            mysql_select_db("mytest", $this->con);
    function logging($id, $mm) // 登录
        $this->zh = $id;
        $this->mm = $mm;
        if (! $this->checkZh()) {
            return false;
        // 判断字段是否存在
        $result = mysql_query("SELECT * FROM teacher WHERE id=$id");
            $row = mysql_fetch_array($result);
            $m_mima = $row['mima'];
            $name = $row['name'];
            if ($mm == $m_mima) {
                echo "登录成功";
                return true;
            } else {
                echo "密码错误";
        } else {
            echo "登录失败";
        return false;
    function _ChangeUserName($mid, $mm, $newName)
        $this->zh = $mid;
        $this->mm = $mm;
            echo "账号不存在!";
            return false;
        if (! $this->logging($mid, $mm)) {
            return false;
         echo  $newName . "," . $mm;
         //传过来的是字符串 但是数据库不识别 加上两个单引号转为字符串 '$newName'
       $ret=  mysql_query("UPDATE teacher SET name='$newName' WHERE id=$mid");
       if(!$ret)
           echo " 无法修改用户昵称 ";
    public function   Reg($zh,$mima,$nichen)
        $this->zh = $zh;
        $this->mm = $mima;
        if ($this->checkZh())
            echo "账号已存在";
            return  ;
        if(mysql_query("INSERT INTO teacher (name,id,mima) VALUES ('$nichen',$zh,'$mima')")==false)
            echo "注册失败" ;
        }else{
            echo "注册成功";
    public function __destruct() // 析构函数销毁数据库连接
        mysql_close($this->con);
$pcode = $_GET['code'];
$obj = json_decode($pcode);
echo  $pcode . "," . $obj->pwd;
$pobj = new zhClass();
if ($obj->type == 0) {
    $pobj->logging($obj->id, $obj->pwd);
}elseif($obj->type==1)
    echo "尝试修改昵称**";
    $pobj->_ChangeUserName($obj->id, $obj->pwd, $obj->_newName);
}elseif ($obj->type==2){
    $pobj->Reg($obj->id, $obj->pwd, $obj->_newName);
ApplicationWindow {
    visible: true
    width: 640
    height: 480
    title: qsTr("Hello World")
    //注册
    function  regFunc()
        var  x = new XMLHttpRequest();
        x.onreadystatechange =function()
            if(x.readyState == 4) {
                if(x.status == 200) {
                    console.log("The server replied with: " + x.responseText);
                    txt.text = x.responseText;
        var xxx = new Object;
        xxx.id=289672082;
        xxx.pwd = '12345';
        xxx._newName='阿央0705';
        xxx.type=2;
      var pcode=  JSON.stringify(xxx);
       x.open("GET","http://localhost/mycode/Test/index.php?code="+pcode);
        x.send(null);
    function  logging()
                xxx.id=289672082;
                xxx.pwd = '12345';
                xxx.type=0;
                x.send(null);
        function _ChangeName()
            xxx.id=289672082;
            xxx.pwd = '12345';
            xxx.type=1;
            xxx._newName='沫、D';
            x.send(null);
    Component.onCompleted: {
        regFunc();
    Text {
        text: qsTr("text")
        textFormat: Text.RichText
    //UPDATE `teacher` SET `name`='hello'  WHERE  id=12
摘 要:“Apache+php+ MySQL”组成了一套完整的开发B/S架构的网络信息系统的工具。文中以该套工具开发产品售后服务管理系统为例,介绍了开发过程中的技术难点及解决方法。
关键字: Apache php MySQL 产品售后服务管理系统
PHP 7.4.9 版本现已发布,具体更新内容如下:Apache:修复了错误#79030(升级 apache2handler 的 php_apache_sapi_get_request_time 以返
关键字: php
如果使用美国服务器创建网站,则必须在美国服务器系统上创建环境。 今天,我将介绍美国服务器Linux系统的工作方式。
关键字: apache Linux php
近日消息,PHP 8.0将于11月发布,但当这个重要的新版本出现时,它遇到了很大的挫折,Windows将不支持它,原因未知。
关键字: php Windows 微软
2020 年 6 月 8 日,PHP 迎来了自己的 25 周岁生日。JetBrains 在博客中梳理了该语言自 1995 年诞生以来的种种历程,这种语言最初是用 C 语言编写的一组通用网关接口(C
关键字: php
#include void TQmlHelper::makeDoc( QQuickTextDocument* doc) { jAVA_QMessage("开始"); QT
关键字: qtquick
function logging() { var x = new XMLHttpRequest(); x.onre
关键字: php
C++需要实现PHP端的:bin2Hex函数,PHP通过这种类型的字符串调用:pack转换成PHP能识别的2进制数据。 C++需要做的是实现一个bin2hex,其实只是把c++读取的2进制数据当成b
关键字: C语言 php
方法一: 在 php 端 header('HTTP/1.1 204 No Content '); 利用http的原理进行 方法二:利用src图片加载的特性完成请求 写一个函数,函数体内 var i
关键字: php
php与nginx整合 PHP-FPM也是一个第三方的FastCGI进程管理器,它是作为PHP的一个补丁来开发的,在安装的时候也需要和PHP源码一起编译,也就是说PHP-FPM被编译到PHP内核中,因
关键字: nginx php
