当前位置:首页 > 工业控制 > 电子设计自动化
[导读] Broadcom 公司的BCM7335 是高清PVR卫星机顶盒片上系统(SoC),它集成了双调谐器/解调器BCM4506前端技术以及支持多种视频格式的最新一代的AVC译码器,支持用于基于DVB-S2和 8PSK的DBS传输系统的世界标准。BCM7335工作在
BCM7335工作在运行于450-MHz的双线程MIPS CPU核,具有超过950 DMIPS的性能。本文介绍了BCM7335的主要性能及优势,单片系统方框图和参考设计方框图。
BCM7335:High-Definition PVR Satellite System-on-Chip
The BCM7335 is Broadcom’s next-generation satellite PVR set-top box system on a single chip in 65-nm process. It integrates the dual-tuner/ demodulator BCM4506 front-end technology and the latest generation of AVC decoder that supports multiple video formats. The BCM7335 supports worldwide standards for DBS transmission systems based on DVB-S2, 8PSK, and is backward compatible with the DVB-S standards. The BCM7335 operates on a dual-threaded MIPS CPU core running at 450-MHz and yielding over 950 DMIPS in performance. The BCM7335 is designed to support UMA and non-UMA memory architectures, utilizing a 400-MHz clock, 32 + 16-bit wide Double Data Rate (DDR2) memory I/F for enhanced performance and allows cost-effective memory solutions. The BCM7335 is a true single chip that can decode transport streams delivered via the integrated DBS front ends. In addition, it is capable of decoding external TS input from 10/100 Ethernet port or via the dual SATA interface for DVR applications with full trick mode support. Several interfaces required for TV output are integrated on-chip including the HDMI, baseband composite, component, or S-Video. An RF channel 3/4 modulated output is also integrated on chip. An HD video encoder with copy protection that supports NTSC, PAL, and SECAM with simultaneous SD output and optional Macrovision/DCS support is integrated on chip as well. The BCM7335 incorporates Broadcom’s advanced 2D graphics engine, offering true studio-quality text and graphics with extremely efficient use of memory and bandwidth. A full range of peripheral devices is supported on the BCM7335, including UARTs, dual ISO7816 smart card interfaces, GPIO, counters/ timers, IR Tx/Rx, UHF Rx, I2C, and SPI controllers.
主要特性:
Dual-integrated wide-band silicon tuners with DiSEqC 2.x and programmable FSKtransceiver•Integrated demods
Dual DVB-S2 8PSK Demods
QPSK demod (market-dependant)
AVC-compliant video decoder for MPEG-4 Parts 2 and 10, MPEG-2, VC-1, ATSC, DivX, Xvid
Programmable decoder supports multiple formats includingMPEG Layers 1 and 2, AC3, AAC, PCM Audio•Multi-threaded MIPS CPU
450 MHz, 32-KB I/D, 128-KB L2
MMU and FPU support, EJTAG debug interface
400-MHz Clock (800-MHz Data) rate DDR2 memory configurable in UMA and non-UMA modes•NAND/NOR flash support
Rich 2D graphics based on Broadcom® Graphics Engine
Dual SATA-2 with eSATA support
Dual 10/100 Ethernet with PHY and MII
Three USB 2.0 ports•On-chip Security Processor
Low cost DVB-CI support
主要优势:
Provides a cost-effective single-chip solution for high-definition Direct Broadcast Satellite (DBS) applications with watch-and-record capabilities.
Based on field-proven and production-ready subsystems offering energy-efficient performance.
Feature-rich, fully integrated SoC reduces the external components needed and reduces PCB real-estate.
Allows cost-effective DDR2-based memory with support for UMA and non-UMA modes.
Advanced 2D-graphics system allows a variety of applications to deliver studio-quality text and graphics on television screens.
Broadcom-developed device drivers enable rapid software development cycles with support of industry-standard operation systems.
Industry-leading third party operating systems, toolchains and middleware supported.
65 nm process technology offers low power and lower cost.
图1BCM7335单片系统方框图
图2BCM7335参考设计框图
LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: 驱动电源
在工业自动化蓬勃发展的当下,工业电机作为核心动力设备,其驱动电源的性能直接关系到整个系统的稳定性和可靠性。其中,反电动势抑制与过流保护是驱动电源设计中至关重要的两个环节,集成化方案的设计成为提升电机驱动性能的关键。
关键字: 工业电机 驱动电源
LED 驱动电源作为 LED 照明系统的 “心脏”,其稳定性直接决定了整个照明设备的使用寿命。然而,在实际应用中,LED 驱动电源易损坏的问题却十分常见,不仅增加了维护成本,还影响了用户体验。要解决这一问题,需从设计、生...
关键字: 驱动电源 照明系统 散热
根据LED驱动电源的公式,电感内电流波动大小和电感值成反比,输出纹波和输出电容值成反比。所以加大电感值和输出电容值可以减小纹波。
关键字: LED 设计 驱动电源
电动汽车(EV)作为新能源汽车的重要代表,正逐渐成为全球汽车产业的重要发展方向。电动汽车的核心技术之一是电机驱动控制系统,而绝缘栅双极型晶体管(IGBT)作为电机驱动系统中的关键元件,其性能直接影响到电动汽车的动力性能和...
关键字: 电动汽车 新能源 驱动电源
在现代城市建设中,街道及停车场照明作为基础设施的重要组成部分,其质量和效率直接关系到城市的公共安全、居民生活质量和能源利用效率。随着科技的进步,高亮度白光发光二极管(LED)因其独特的优势逐渐取代传统光源,成为大功率区域...
关键字: 发光二极管 驱动电源 LED
LED通用照明设计工程师会遇到许多挑战,如功率密度、功率因数校正(PFC)、空间受限和可靠性等。
关键字: LED 驱动电源 功率因数校正
在LED照明技术日益普及的今天,LED驱动电源的电磁干扰(EMI)问题成为了一个不可忽视的挑战。电磁干扰不仅会影响LED灯具的正常工作,还可能对周围电子设备造成不利影响,甚至引发系统故障。因此,采取有效的硬件措施来解决L...
关键字: LED照明技术 电磁干扰 驱动电源
开关电源具有效率高的特性,而且开关电源的变压器体积比串联稳压型电源的要小得多,电源电路比较整洁,整机重量也有所下降,所以,现在的LED驱动电源
关键字: LED 驱动电源 开关电源
LED驱动电源是把电源供应转换为特定的电压电流以驱动LED发光的电压转换器,通常情况下:LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: LED 隧道灯 驱动电源
