VBA:Excel使用SQL进行查询
Sub Query()
Dim Conn As Object, Rst As Object
Dim strConn As String, strSQL As String
Dim i As Integer, PathStr As String
Set Conn = CreateObject("ADODB.Connection")
Set Rst = CreateObject("ADODB.Recordset")
PathStr = ThisWorkbook.FullName '设置工作簿的完整路径和名称
Select Case Application.Version * 1 '设置连接字符串,根据版本创建连接
Case Is = 12
strConn = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & PathStr & ";Extended Properties=""Excel 12.0;HDR=YES"";"""
End Select
'设置SQL查询语句
strSQL = "SELECT DISTINCT 发站 FROM [LMSData2016.12$]"
Conn.Open strConn '打开数据库链接
Set Rst = Conn.Execute(strSQL) '执行查询,并将结果输出到记录集对象
With Sheet1
.Cells.Clear
For i = 0 To Rst.Fields.Count - 1 '填写标题
.Cells(1, i + 1) = Rst.Fields(i).Name
Next i
.Range("A2").CopyFromRecordset Rst
.Cells.EntireColumn.AutoFit '自动调整列宽
End With
Rst.Close '关闭数据库连接
Conn.Close
Set Conn = Nothing
Set Rst = Nothing
End Sub
