当前位置:首页 > 单片机 > 单片机
[导读] constcharQFDZ[4][32]={{0x10,0x10,0x17,0x15,0x95,0x75,0x57,0x10,0x10,0x13,0x30,0xD0,0x57,0x10,0x10,0x00,0x00,0x00,0xFE,0x20,0x24,0x22,0xFC,0x00,0x00,0xF8,0x02,0x01,0xFE,0x00,0x00,0x00},//前
{0x10,0x10,0x10,0x10,0x10,0x10,0x9F,0x52,0x32,0x12,0x12,0x13,0x10,0x10,0x10,0x00,
0x02,0x02,0x04,0x08,0x30,0xC0,0x00,0x00,0x04,0x02,0x02,0xFC,0x00,0x00,0x00,0x00},//方
{0x00,0x44,0x4E,0x54,0x64,0x47,0x54,0x4E,0x44,0x00,0x1F,0x00,0x00,0xFF,0x00,0x00,
0x00,0x42,0x43,0x42,0x44,0xFC,0x44,0x48,0x48,0x00,0xF0,0x02,0x01,0xFE,0x00,0x00},//到
{0x08,0x0A,0x49,0x38,0x08,0x0F,0x08,0x00,0x00,0x00,0xFF,0x08,0x08,0x08,0x08,0x00,
0x08,0x08,0xD0,0x30,0xD0,0x10,0x00,0xFE,0x84,0x84,0x84,0x84,0x84,0xFE,0x00,0x00}//站
constcharDL[2][32]={
{0x00,0x40,0x40,0x40,0x40,0x40,0x40,0x4F,0x48,0x50,0x50,0x60,0x60,0x40,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x02,0x01,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}//了
constcharState1[3][32]={
{0x08,0x10,0x20,0xCB,0x6A,0x5A,0x4A,0x5A,0x2F,0xCA,0x6A,0x5A,0x4E,0x40,0x40,0x00,
0x00,0x04,0x04,0xC4,0x48,0x48,0x50,0x60,0xFF,0x40,0x40,0x48,0x44,0x78,0x00,0x00},//第
{0x00,0x08,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x04,0xFC,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//1
constcharState2[3][32]={
{0x00,0x0E,0x10,0x10,0x10,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0C,0x14,0x24,0x44,0x84,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//2
constcharState3[3][32]={
{0x00,0x0C,0x10,0x11,0x11,0x12,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x18,0x04,0x04,0x04,0x88,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//3
constcharState4[3][32]={
{0x00,0x00,0x03,0x04,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xE0,0x20,0x24,0x24,0xFC,0x24,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//4
constcharState5[3][32]={
{0x00,0x1F,0x10,0x11,0x11,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x98,0x84,0x04,0x04,0x88,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//5
constcharState6[3][32]={
{0x00,0x07,0x08,0x11,0x11,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xF0,0x88,0x04,0x04,0x88,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//6
constcharState7[3][32]={
{0x00,0x1C,0x10,0x10,0x13,0x1C,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//7
constcharState8[3][32]={
{0x00,0x0E,0x11,0x10,0x10,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x38,0x44,0x84,0x84,0x44,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//8
constcharState9[3][32]={
{0x00,0x07,0x08,0x10,0x10,0x08,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x8C,0x44,0x44,0x88,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//9
constcharState10[3][32]={
{0x00,0x08,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x07,0x08,0x10,0x10,0x08,0x07,0x00,
0x00,0x04,0x04,0xFC,0x04,0x04,0x00,0x00,0x00,0xF0,0x08,0x04,0x04,0x08,0xF0,0x00},//10
constcharState11[3][32]={
{0x00,0x08,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x1F,0x00,0x00,0x00,0x00,
0x00,0x04,0x04,0xFC,0x04,0x04,0x00,0x00,0x00,0x04,0x04,0xFC,0x04,0x04,0x00,0x00},//11
constcharState12[3][32]={
{0x00,0x08,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x0E,0x10,0x10,0x10,0x11,0x0E,0x00,
0x00,0x04,0x04,0xFC,0x04,0x04,0x00,0x00,0x00,0x0C,0x14,0x24,0x44,0x84,0x0C,0x00},//12
constcharState13[3][32]={
{0x00,0x08,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x0C,0x10,0x11,0x11,0x12,0x0C,0x00,
0x00,0x04,0x04,0xFC,0x04,0x04,0x00,0x00,0x00,0x18,0x04,0x04,0x04,0x88,0x70,0x00},//13
constcharState14[3][32]={
{0x00,0x08,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x04,0x08,0x1F,0x00,0x00,
0x00,0x04,0x04,0xFC,0x04,0x04,0x00,0x00,0x00,0xE0,0x20,0x24,0x24,0xFC,0x24,0x00},//14
constcharState15[3][32]={
{0x00,0x08,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x1F,0x10,0x11,0x11,0x10,0x10,0x00,
0x00,0x04,0x04,0xFC,0x04,0x04,0x00,0x00,0x00,0x98,0x84,0x04,0x04,0x88,0x70,0x00},//15
constcharState16[3][32]={
{0x00,0x08,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x07,0x08,0x11,0x11,0x18,0x00,0x00,
0x00,0x04,0x04,0xFC,0x04,0x04,0x00,0x00,0x00,0xF0,0x88,0x04,0x04,0x88,0x70,0x00},//16
};*/AVR单片机
LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: 驱动电源
在工业自动化蓬勃发展的当下,工业电机作为核心动力设备,其驱动电源的性能直接关系到整个系统的稳定性和可靠性。其中,反电动势抑制与过流保护是驱动电源设计中至关重要的两个环节,集成化方案的设计成为提升电机驱动性能的关键。
关键字: 工业电机 驱动电源
LED 驱动电源作为 LED 照明系统的 “心脏”,其稳定性直接决定了整个照明设备的使用寿命。然而,在实际应用中,LED 驱动电源易损坏的问题却十分常见,不仅增加了维护成本,还影响了用户体验。要解决这一问题,需从设计、生...
关键字: 驱动电源 照明系统 散热
根据LED驱动电源的公式,电感内电流波动大小和电感值成反比,输出纹波和输出电容值成反比。所以加大电感值和输出电容值可以减小纹波。
关键字: LED 设计 驱动电源
电动汽车(EV)作为新能源汽车的重要代表,正逐渐成为全球汽车产业的重要发展方向。电动汽车的核心技术之一是电机驱动控制系统,而绝缘栅双极型晶体管(IGBT)作为电机驱动系统中的关键元件,其性能直接影响到电动汽车的动力性能和...
关键字: 电动汽车 新能源 驱动电源
在现代城市建设中,街道及停车场照明作为基础设施的重要组成部分,其质量和效率直接关系到城市的公共安全、居民生活质量和能源利用效率。随着科技的进步,高亮度白光发光二极管(LED)因其独特的优势逐渐取代传统光源,成为大功率区域...
关键字: 发光二极管 驱动电源 LED
LED通用照明设计工程师会遇到许多挑战,如功率密度、功率因数校正(PFC)、空间受限和可靠性等。
关键字: LED 驱动电源 功率因数校正
在LED照明技术日益普及的今天,LED驱动电源的电磁干扰(EMI)问题成为了一个不可忽视的挑战。电磁干扰不仅会影响LED灯具的正常工作,还可能对周围电子设备造成不利影响,甚至引发系统故障。因此,采取有效的硬件措施来解决L...
关键字: LED照明技术 电磁干扰 驱动电源
开关电源具有效率高的特性,而且开关电源的变压器体积比串联稳压型电源的要小得多,电源电路比较整洁,整机重量也有所下降,所以,现在的LED驱动电源
关键字: LED 驱动电源 开关电源
LED驱动电源是把电源供应转换为特定的电压电流以驱动LED发光的电压转换器,通常情况下:LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: LED 隧道灯 驱动电源
