当前位置:首页 > 单片机 > 单片机
[导读]I2C(Inter-Integrated Circuit)总线是一种两线式串行总线,用于连接微控制器及其外围设备。和SPI一样,也是一种常用的串行通信方式。STM32微控制器提供硬件I2C,对它进行相应配置就可以用来进行多个设备之间的通信
STM32微控制器提供硬件I2C,对它进行相应配置就可以用来进行多个设备之间的通信。
使用步骤:
1. Enable peripheral clock
2. Enable SDA, SCL and SMBA (when used) GPIO clocks
3. Peripherals alternate function:? Call GPIO_Init() function.
4. Program the Mode, Timing , Own address, Ack and Acknowledged Address using the I2C_Init() function.
5. Enable the NVIC and the corresponding interrupt if you need to use interrupt mode.
7. When using the DMA mode Configure the DMA
8. Enable the I2C using the I2C_Cmd() function.
9. Enable the DMA when using DMA mode in the transfers.
基于STM32F3discovery开发板
MCU:STM32F303VC作为主机
从机”LSM303DLHC加速度计/磁强计
使用I2C1,引脚:PB6—I2C1_SCL,PB7—I2C1_SDA
代码:
void I2C_Config(void)
I2C_InitTypeDef I2C_InitStructure;
RCC_AHBPeriphClockCmd(I2C_GPIO_CLK, ENABLE);
RCC_APB1PeriphClockCmd(LSM303DLHC_I2C_CLK, ENABLE);
GPIO_PinAFConfig(I2C_GPIO_PORT, I2C_SCK_SOURCE, I2C_SCK_AF);
GPIO_PinAFConfig(I2C_GPIO_PORT, I2C_SDA_SOURCE, I2C_SDA_AF);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;//GPIO_PuPd_DOWN;
GPIO_InitStructure.GPIO_Pin =I2C_SCK_PIN;
GPIO_Init(I2C_GPIO_PORT, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin =I2C_SDA_PIN;
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_AnalogFilter= I2C_AnalogFilter_Enable;
I2C_InitStructure.I2C_DigitalFilter= 0x00;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_OwnAddress1=0x00;
I2C_InitStructure.I2C_Timing = 0x00902025;
I2C_Init(LSM303DLHC_I2C,&I2C_InitStructure);
I2C_Cmd(LSM303DLHC_I2C, ENABLE);
uint16_t LSM303DLHC_myRead(uint8_t DeviceAddr, uint8_t RegAddr, uint8_t* pBuffer, uint16_t NumByteToRead)
while(I2C_GetFlagStatus(LSM303DLHC_I2C,I2C_FLAG_BUSY)!=RESET);
I2C_TransferHandling(LSM303DLHC_I2C,DeviceAddr,1,I2C_SoftEnd_Mode,I2C_Generate_Start_Write);
while(I2C_GetFlagStatus(LSM303DLHC_I2C,I2C_FLAG_TXIS)==RESET);
if(NumByteToRead>1)
RegAddr |= 0x80; //读多字节指令
I2C_SendData(LSM303DLHC_I2C,(u8)RegAddr);
while(I2C_GetFlagStatus(LSM303DLHC_I2C,I2C_FLAG_TC));
I2C_TransferHandling(LSM303DLHC_I2C,DeviceAddr,NumByteToRead,I2C_AutoEnd_Mode,I2C_Generate_Start_Read);
while(NumByteToRead>0)
while(I2C_GetFlagStatus(LSM303DLHC_I2C,I2C_FLAG_RXNE)==RESET);
*pBuffer = I2C_ReceiveData(LSM303DLHC_I2C);
pBuffer++;
NumByteToRead--;
while(I2C_GetFlagStatus(LSM303DLHC_I2C,I2C_FLAG_STOPF)==RESET);
I2C_ClearFlag(LSM303DLHC_I2C,I2C_FLAG_STOPF);
return 1;
uint16_t LSM303DLHC_myWrite(uint8_t DeviceAddr, uint8_t RegAddr, uint8_t* pBuffer)
while(I2C_GetFlagStatus(LSM303DLHC_I2C,I2C_FLAG_BUSY)!=0);
while(I2C_GetFlagStatus(LSM303DLHC_I2C,I2C_FLAG_TXIS)==0);
I2C_SendData(LSM303DLHC_I2C,RegAddr);
while(I2C_GetFlagStatus(LSM303DLHC_I2C,I2C_FLAG_TC)==0);
I2C_TransferHandling(LSM303DLHC_I2C,DeviceAddr,1,I2C_AutoEnd_Mode,I2C_Generate_Start_Write);
I2C_SendData(LSM303DLHC_I2C,*pBuffer);
while(I2C_GetFlagStatus(LSM303DLHC_I2C,I2C_FLAG_STOPF)==0);
return 1;
然后根据需要设置LSM303DLHC初始化参数,就可以用上面的读数据函数不断读取传感器内数据寄存器的值,进行后续数据处理。
LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: 驱动电源
在工业自动化蓬勃发展的当下,工业电机作为核心动力设备,其驱动电源的性能直接关系到整个系统的稳定性和可靠性。其中,反电动势抑制与过流保护是驱动电源设计中至关重要的两个环节,集成化方案的设计成为提升电机驱动性能的关键。
关键字: 工业电机 驱动电源
LED 驱动电源作为 LED 照明系统的 “心脏”,其稳定性直接决定了整个照明设备的使用寿命。然而,在实际应用中,LED 驱动电源易损坏的问题却十分常见,不仅增加了维护成本,还影响了用户体验。要解决这一问题,需从设计、生...
关键字: 驱动电源 照明系统 散热
根据LED驱动电源的公式,电感内电流波动大小和电感值成反比,输出纹波和输出电容值成反比。所以加大电感值和输出电容值可以减小纹波。
关键字: LED 设计 驱动电源
电动汽车(EV)作为新能源汽车的重要代表,正逐渐成为全球汽车产业的重要发展方向。电动汽车的核心技术之一是电机驱动控制系统,而绝缘栅双极型晶体管(IGBT)作为电机驱动系统中的关键元件,其性能直接影响到电动汽车的动力性能和...
关键字: 电动汽车 新能源 驱动电源
在现代城市建设中,街道及停车场照明作为基础设施的重要组成部分,其质量和效率直接关系到城市的公共安全、居民生活质量和能源利用效率。随着科技的进步,高亮度白光发光二极管(LED)因其独特的优势逐渐取代传统光源,成为大功率区域...
关键字: 发光二极管 驱动电源 LED
LED通用照明设计工程师会遇到许多挑战,如功率密度、功率因数校正(PFC)、空间受限和可靠性等。
关键字: LED 驱动电源 功率因数校正
在LED照明技术日益普及的今天,LED驱动电源的电磁干扰(EMI)问题成为了一个不可忽视的挑战。电磁干扰不仅会影响LED灯具的正常工作,还可能对周围电子设备造成不利影响,甚至引发系统故障。因此,采取有效的硬件措施来解决L...
关键字: LED照明技术 电磁干扰 驱动电源
开关电源具有效率高的特性,而且开关电源的变压器体积比串联稳压型电源的要小得多,电源电路比较整洁,整机重量也有所下降,所以,现在的LED驱动电源
关键字: LED 驱动电源 开关电源
LED驱动电源是把电源供应转换为特定的电压电流以驱动LED发光的电压转换器,通常情况下:LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: LED 隧道灯 驱动电源
