当前位置:首页 > 芯闻号 > 充电吧
[导读]原文转载于:https://blog.csdn.net/wytdahu/article/details/47130405Python:渗透测试开源项目【源码值得精读】sql注入工具:sqlmapDNS
sql注入工具:sqlmap
DNS安全监测:DNSRecon
暴力破解测试工具:patator
XSS漏洞利用工具:XSSer
Web服务器压力测试工具:HULK
SSL安全扫描器:SSLyze
网络
Scapy: send, sniff and dissect and forge network packets. Usable interactively or as a library
pypcap, Pcapy and pylibpcap: several different Python bindings for libpcap
libdnet: low-level networking routines, including interface lookup and Ethernet frame transmission
dpkt: fast, simple packet creation/parsing, with definitions for the basic TCP/IP protocols
Impacket: craft and decode network packets. Includes support for higher-level protocols such as NMB and SMB
pynids: libnids wrapper offering sniffing, IP defragmentation, TCP stream reassembly and port scan detection
Dirtbags py-pcap: read pcap files without libpcap
flowgrep: grep through packet payloads using regular expressions
Knock Subdomain Scan, enumerate subdomains on a target domain through a wordlist
Mallory, extensible TCP/UDP man-in-the-middle proxy, supports modifying non-standard protocols on the fly
Pytbull: flexible IDS/IPS testing framework (shipped with more than 300 tests)
调试和逆向工程
Paimei: reverse engineering framework, includes PyDBG, PIDA, pGRAPH
Immunity Debugger: scriptable GUI and command line debugger
mona.py: PyCommand for Immunity Debugger that replaces and improves on pvefindaddr
IDAPython: IDA Pro plugin that integrates the Python programming language, allowing scripts to run in IDA Pro
PyEMU: fully scriptable IA-32 emulator, useful for malware analysis
pefile: read and work with Portable Executable (aka PE) files
pydasm: Python interface to the libdasm x86 disassembling library
PyDbgEng: Python wrapper for the Microsoft Windows Debugging Engine
uhooker: intercept calls to API calls inside DLLs, and also arbitrary addresses within the executable file in memory
diStorm: disassembler library for AMD64, licensed under the BSD license
python-ptrace: debugger using ptrace (Linux, BSD and Darwin system call to trace processes) written in Python
vdb / vtrace: vtrace is a cross-platform process debugging API implemented in python, and vdb is a debugger which uses it
Androguard: reverse engineering and analysis of Android applications
Fuzzing
Sulley: fuzzer development and fuzz testing framework consisting of multiple extensible components
Peach Fuzzing Platform: extensible fuzzing framework for generation and mutation based fuzzing (v2 was written in Python)
antiparser: fuzz testing and fault injection API
TAOF, (The Art of Fuzzing) including ProxyFuzz, a man-in-the-middle non-deterministic network fuzzer
untidy: general purpose XML fuzzer
Powerfuzzer: highly automated and fully customizable web fuzzer (HTTP protocol based application fuzzer)
SMUDGE
Mistress: probe file formats on the fly and protocols with malformed data, based on pre-defined patterns
Fuzzbox: multi-codec media fuzzer
Forensic Fuzzing Tools: generate fuzzed files, fuzzed file systems, and file systems containing fuzzed files in order to test the robustness of forensics tools and examination systems
Windows IPC Fuzzing Tools: tools used to fuzz applications that use Windows Interprocess Communication mechanisms
WSBang: perform automated security testing of SOAP based web services
Construct: library for parsing and building of data structures (binary or textual). Define your data structures in a declarative manner
fuzzer.py (feliam): simple fuzzer by Felipe Andres Manzano
Fusil: Python library used to write fuzzing programs
Web
Requests: elegant and simple HTTP library, built for human beings
HTTPie: human-friendly cURL-like command line HTTP client
ProxMon: processes proxy logs and reports discovered issues
WSMap: find web service endpoints and discovery files
Twill: browse the Web from a command-line interface. Supports automated Web testing
Ghost.py: webkit web client written in Python
Windmill: web testing tool designed to let you painlessly automate and debug your web application
FunkLoad: functional and load web tester
spynner: Programmatic web browsing module for Python with Javascript/AJAX support
python-spidermonkey: bridge to the Mozilla SpiderMonkey JavaScript engine; allows for the evaluation and calling of Javascript scripts and functions
mitmproxy: SSL-capable, intercepting HTTP proxy. Console interface allows traffic flows to be inspected and edited on the fly
pathod / pathoc: pathological daemon/client for tormenting HTTP clients and servers
取证
Volatility: extract digital artifacts from volatile memory (RAM) samples
LibForensics: library for developing digital forensics applications
TrIDLib, identify file types from their binary signatures. Now includes Python binding
aft: Android forensic toolkit
恶意程序分析
pyew: command line hexadecimal editor and disassembler, mainly to analyze malware
Exefilter: filter file formats in e-mails, web pages or files. Detects many common file formats and can remove active content
pyClamAV: add virus detection capabilities to your Python software
jsunpack-n, generic JavaScript unpacker: emulates browser functionality to detect exploits that target browser and browser plug-in vulnerabilities
yara-python: identify and classify malware samples
phoneyc: pure Python honeyclient implementation
PDF
Didier Stevens' PDF tools: analyse, identify and create PDF files (includes PDFiD, pdf-parserand make-pdf and mPDF)
Opaf: Open PDF Analysis Framework. Converts PDF to an XML tree that can be analyzed and modified.
Origapy: Python wrapper for the Origami Ruby module which sanitizes PDF files
pyPDF: pure Python PDF toolkit: extract info, spilt, merge, crop, encrypt, decrypt…
PDFMiner: extract text from PDF files
python-poppler-qt4: Python binding for the Poppler PDF library, including Qt4 support
Misc
InlineEgg: toolbox of classes for writing small assembly programs in Python
Exomind: framework for building decorated graphs and developing open-source intelligence modules and ideas, centered on social network services, search engines and instant messaging
RevHosts: enumerate virtual hosts for a given IP address
simplejson: JSON encoder/decoder, e.g. to use Google's AJAX API
PyMangle: command line tool and a python library used to create word lists for use with other penetration testing tools
Hachoir: view and edit a binary stream field by field
py-mangle: command line tool and a python library used to create word lists for use with other penetration testing tools
其他有用的Py库和工具
IPython: enhanced interactive Python shell with many features for object introspection, system shell access, and its own special command system
Beautiful Soup: HTML parser optimized for screen-scraping
matplotlib: make 2D plots of arrays
Mayavi: 3D scientific data visualization and plotting
RTGraph3D: create dynamic graphs in 3D
Twisted: event-driven networking engine
Suds: lightweight SOAP client for consuming Web Services
M2Crypto: most complete OpenSSL wrapper
NetworkX: graph library (edges, nodes)
Pandas: library providing high-performance, easy-to-use data structures and data analysis tools
pyparsing: general parsing module
lxml: most feature-rich and easy-to-use library for working with XML and HTML in the Python language
Whoosh: fast, featureful full-text indexing and searching library implemented in pure Python
Pexpect: control and automate other programs, similar to Don Libes `Expect` system
Sikuli, visual technology to search and automate GUIs using screenshots. Scriptable inJython
PyQt and PySide: Python bindings for the Qt application framework and GUI library
其他
Python 作为程序员的宠儿,越来越得到人们的关注,使用 Python 进行应用程序开发的越来也多。那么,在 2013 年有哪些流行的 Python 项目呢?下面,我们一起来看下。
  一、测试和调试
python_koans:Python Koans 算 “Ruby Koans” 的一部分,作为交互式教程,可以学习 TDD 技巧。sure:Sure 是最适合自动化测试的 Python 工具,包含流利的断言、深度选择器等等特性。responses:用 responses 能令测试更加轻松,这是一个可以伪装各种请求的库。boom:Boom! Apache Bench 的替代品。作为一个命令行工具,Boom 能对你的应用进行快捷的 smoke test。cricket:BeeWare 套件的一部分,cricket 是种图形化工具,协助你进行案例测试。bugjar:BeeWare 套件的一部分,bugjar 是针对 Python 的图形化交互式调试器。pudb:pudn 是针对 Python 的全屏命令行调试器。voltron:更好的 gdb 界面。
  二、Web 框架
django-stronghold:试过将 login_required 装饰器四处乱放? 在你的堡垒中令所有 Django 视图有默认 login_required 呗。Falcon Framework:Falcon 自称为髙性能云接口框架,号称能在相同硬件条件下提高服务端性能 30 倍! 听起来有点儿意思?django-xadmin:用 bootstrap 对 django-admin 进行了深度升级,提供了可插件安装的仪表盘。clay:基于 Flask 的封装,能令我们轻松的创建 RESTful 后端服务,完整文档可查看 clay。flask-restful:基于 Flask 的简单框架,用以创建 REST 接口。sandman:Sandman 希望通过 REST 接口暴露你现有的 app,相关 博客也值得一读。Django Unchained:名字很髙大上,也的确是 Python Django 初学者的靠谱指南。
  三、并发
pulsar:部署新 web 服务器走起! 有趣的事件驱动的并发框架 ! 兼容从 2.6+ 到 pypy 的所有 python 版本!toro:同步化的 Tornado 协程支持。offset:Offset Go 的并发模式在 Python 中的实现,请参考相关演讲 幻灯来理解!
  四、任务调度
pyres:从 resque 获得灵感的纯 Python 任务调度模块,是 celery 的替代。dagobah:Dagobah 是 Python 完成的简单关系依赖为基础的任务调度模块,还包含很 COOL 的关联任务工作流图形工具。schedule:使用生成器模式来为定期任务生成配置的进程调度模块。
  五、实用工具
howdoi:发觉你总在 Google 一些简单的最简单的编程任务? howdoi 能让你远离浏览器,就解决这类事儿!delorean:时间旅行?简单! Delorean 的目标就是令你的 Python 项目在处理时间/日期时轻而易举!查阅完备的 文档。powerline-shell:对于那些想让常用工具漂亮起来人,一定要用 powerline-bash,能打造漂亮的 shell 提示符,增加力线(powerline),兼容 Bash/Zsh。fn.py:在 Python 中谈及函数编程时失落的那节"电池"终于出现了! 如果对 Python 函数式编程有兴趣的立即下手安装体验吧!lice:为你的开源工程方便的追加许可证,而不用自个儿去 Google,支持 BSD、MIT 和 GPL 以及变种协议。usblock:基于 USB 来锁定或是解锁你的笔记本!Matchbox:MatchBox 能在你自个儿的服务器上提供类似 Dropbox 风格的备份服务! 基于 Flask 并通过 http 协议进行文件传输。cleanify:用 cleanify 能异步美化你项目的所有 html/css/js 文件。locksmith:Locksmith 是 AES 加密的口令管理器,看起来不错,完全开源,源代码、截屏都有。storm:在 Storm 的命令行界面,管理你所有的 SSH 连接。sqlparse::这个很给力! sqlparse 是个 SQL 有效性分析器,支持解析/分裂/格式化 SQL 语句。autopep8:能自动化以 pep8来格式化你的代码。colout:colout 用以在命令行中色彩化输出,这就从其 github page 查看范例来体验吧。bumpversion:版本号冲撞总是恼人的,而每个人总是忘记给发行版本打 tag,bumpversion 用一条简单的命令简化了这方面的操作。pyenv:需要更好的管理你 Python 的多版本环境 ? pyenv 让你能简洁的作到!(甚至超出你的预期!有插件能将 VirtualEnv 也无缝结合进来!)pip-tools:一整套能令你的 Python 项目保持清爽的工具。cdiff:Cdiff 是种非常 nice 的工具,可以用彩色输出统一 diff 格式信息,或用双栏形式来展示。
  六、数据科学及可视化
data_hacks:由 bitly 发布的一堆数据分析用命令行工具。这些工具接受命令行或是其它工具输入的数据,轻易的生成柱图以及直方图等等。给黒客的概率编程和贝叶斯方法:这书是极好的,介绍如何用贝叶斯方法和概率编程进行数据分析,而且每章都提供了用以 iPython Notebooks 的示例。simmetrica:想对自个儿的应用基于时间的数据序列进行展示、汇总、分享嘛? 赶紧上 simmetrica 吧,同时还提供了可定制的仪表盘。vincent: Python 构建的专为运用 D3.js 进行可视化的 vega 转换工具。bamboo:一种简洁的实时数据分析应用,bamboo 提供了一个进行合并、汇总、数值计算的数据实时接口。dataset:难以置信的工具,dataset 让对数据库的读写简单的象对 JSON 文件的操作,没有其它的文件配置,顷刻间就让你在 BOSS 面前高大上起来。folium:喜欢地图?也爱 Python? Folium 让你在地图上自在操纵数据。prettyplotlib:用 prettyplotlib 来强化你的 matplotlib,让你默认的 matplotlib 输出图片更加漂亮.lifelines:有兴趣在 Python 中研究生存分析的话,不用观望了,用 lifelines! 包含对 Kaplan-Meier、Nelson-Aalen 和生存回归分析。
  七、编辑器及其改善
sublime-snake:想在无尽的 coding 中喘口气? 当然是这种经典游戏了……spyderlib:又一个用 Python 写的开源 IDE。vimfox:对于 Vim 党最贴心的 web 专发工具,VimFox 能让 vim 实时的看到 css/js/html 的修改效果,能神奇的让 vim 中的修订,立即在浏览器中看到。pcode:基于 Py3 的 IDE,通过简单的 UI 提供了重构、工程管理等。
  八、持续交付
metrology:这个库很酷,支持你对应用进行多种测量并轻松输出给类似 graphite 的外部系统。python-lust:支持在 Unix 系统中用 Python 实现一个守护进程。scales:Scales 对你的 Python 应用进行持续状态和统计,并发送数据到 graphite。glances:跨平台,基于 curses 命令行的系统监视工具。ramona:企业级的应用监管。 Ramona 保证每个进程在值,一但需要立即重启,并有监控/日志输出,会发送邮件提醒。salmon:基于 Salt Stack 的多服务监视系统,即能作报警系统,也能当监控系统。graph-explorer:Graph-explorer 是对 Graphite 面板的增强,比原版的好很多,值得体验。sovereign:Sovereign 是一系列 ansible 的攻略手册,能为自个儿建造个私人云。shipyard:能在指定的机器上弹出你的弹窗实例,也支持你创建/删除等等对弹窗的远程控制。docker-py:疯狂的 docker 工程接口的 Python 包装。dockerui:基于 docker 接口通过 web 界面进行交互操作的工具。django-docker:如果想知道怎么将 Djnago 应用同 Docker 结合? 可以从这里学习。diamond:Python 实现的守护进程,自动从你的服务或是其它指定数据源中提取数值,并 graphite、以及其它支持的状态面板/收集系统输出。
  九、Git
git-workflow:可视化你的 git 工作流程的工具,示例: Demo。gitto:简洁的库,协助你建立自个儿的 git 主机。git-imerge:git-imerge 能让 git 进行增量合并。 本质上是允许你在进行 imerge 有冲突时,有机会先合并掉,再继续。
  十、邮件与聊天
mailbox:Mailbox 是对 Python 的 IMAP 一个人性化的再造。 基于简单即是美的态度,作者对 IMAP 接口给出了一个简单又好理解的形式。deadchat:deadchat 旨在不安全的网络环境中提供安全的单一房间群聊服务以及客户端。Mailpile:Mailpile 是针对邮件的索引及搜索引擎 。
  十一、音频和视频
pms:穷人的 Spotify,搜索和收集音乐流!dejavu:在琢磨 Shazam 的原理? 音频指纹识别算法的 Python 实现在此!(译注:Shazam:是个神奇的音乐识别应用,对她啍个几秒调子,就能精确告诉你是什么歌曲、作者、歌词……)HTPC-Manager:为 HTPC 粉丝准备的工具,提供了完备的界面来管理所有家庭媒体服务器上的好物。cherrymusic:Python 实现的一个音乐流媒体服务器。 流化输出你的音乐到所有设备上。moviepy:脚本化的电影剪辑包,切/串/插入标题等基本操作,几行就搞定!
  十二、其它
emit:用 redis 为你的函式追加可订阅能力,很有趣。zipline:Zipline 是种很 Pythonic 的交易算法库。raspberry.io:Raspberry.io 是树莓派的社区实现。 刚刚发布,汇集了各种创意想法,有兴趣的话立即检出折腾吧。NewsBlur:Google Reader 已经关张儿了,Newsblur 已经发布了有段日子了,开源的 RSS 阅读器,这绝对是应该首先体验的。macropy:Macropy 是在 Python 中实现 macros 的库。 检出文档,参考所有功能,看怎么用上了。mini:对编译器以及语言设计有兴趣的,一定要看看这个仓库,以及配套的录像!parsimonious:Parsimonious 的目标是最快的 arbitrary-lookahead 解析器。 用 Python 实现,基本可用。isso:Disqus 的开源替代,从 demo 看很不错,而且提供了更好的隐私设置。deaddrop:Deaddrop 能为新闻机构或是其它人提供在线投递箱,详细信息参考其 github page。nude.py:裸体检测的 Python 实现,是 node.js 的仿制。kaptan: Kaptan 是你应用的配置管理器!luigi:Luigi 帮你构建复杂的管道来完成批处理。gramme:Gramme 以简单而优雅的方式,通过 UDP 接口对易失数据完成消息包装序列化。q:为你的 Python 程序提供快速而随性的日志。 有一系列帮手来追踪你的函式参数,并能在控制台快速交互式加载。fuqit:来自伟大的 Zed Shaw 最新作品,fuqit 试图令你忘记 MVC 的经验,用全新的方式专注简洁一切。simplicity:基于靠谱的 pydanny 将你的新结构化文本转换为 JSON 格式。lassie:Lassie 允许你轻松的从网站检索出内容来。paperwork:Paperwork 是个 OCR 文档并完成可搜索转化的工具,用 GTK/Glade 实现了友好的界面。cheat:cheat 允许你创建并查阅命令行上的交互式备忘。设计目的是帮助 *nix 的系统管理员们在习惯的环境中,快速调阅不易记忆的常用命令。cookiecutter:良心模块! 提供一堆有用但是不常写,所以记不下来的代码模板,也支持自制代码模板。pydown:支持用 Python 构建亮丽的 HTML5 效果幻灯,Demo。Ice:模拟器粉丝们现在能用 Ice 向 Steam 里塞 ROM 来玩了。pants:用以编写异步网络应用的轻量级框架。 Pants 是单线程,回调服务,也包含支持 Websockets 的 HTTP 服务、WSGI 支持和一个简单的 web 框架。pipeless:Pipeless 是一个构建简单 数据管道的框架。marshmallow:marshmallow 是个 ORM 无关的库,能将复杂的数据类型转换为 Python 原生类型对象,以便容易的转换为 JSON 提供接口使用。twosheds:Python 实现的库,用来构造命令或是 shell 解释器。Twosheds 让你用 Python 来定制自个儿的 shell 环境。
LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: 驱动电源
在工业自动化蓬勃发展的当下,工业电机作为核心动力设备,其驱动电源的性能直接关系到整个系统的稳定性和可靠性。其中,反电动势抑制与过流保护是驱动电源设计中至关重要的两个环节,集成化方案的设计成为提升电机驱动性能的关键。
关键字: 工业电机 驱动电源
LED 驱动电源作为 LED 照明系统的 “心脏”,其稳定性直接决定了整个照明设备的使用寿命。然而,在实际应用中,LED 驱动电源易损坏的问题却十分常见,不仅增加了维护成本,还影响了用户体验。要解决这一问题,需从设计、生...
关键字: 驱动电源 照明系统 散热
根据LED驱动电源的公式,电感内电流波动大小和电感值成反比,输出纹波和输出电容值成反比。所以加大电感值和输出电容值可以减小纹波。
关键字: LED 设计 驱动电源
电动汽车(EV)作为新能源汽车的重要代表,正逐渐成为全球汽车产业的重要发展方向。电动汽车的核心技术之一是电机驱动控制系统,而绝缘栅双极型晶体管(IGBT)作为电机驱动系统中的关键元件,其性能直接影响到电动汽车的动力性能和...
关键字: 电动汽车 新能源 驱动电源
在现代城市建设中,街道及停车场照明作为基础设施的重要组成部分,其质量和效率直接关系到城市的公共安全、居民生活质量和能源利用效率。随着科技的进步,高亮度白光发光二极管(LED)因其独特的优势逐渐取代传统光源,成为大功率区域...
关键字: 发光二极管 驱动电源 LED
LED通用照明设计工程师会遇到许多挑战,如功率密度、功率因数校正(PFC)、空间受限和可靠性等。
关键字: LED 驱动电源 功率因数校正
在LED照明技术日益普及的今天,LED驱动电源的电磁干扰(EMI)问题成为了一个不可忽视的挑战。电磁干扰不仅会影响LED灯具的正常工作,还可能对周围电子设备造成不利影响,甚至引发系统故障。因此,采取有效的硬件措施来解决L...
关键字: LED照明技术 电磁干扰 驱动电源
开关电源具有效率高的特性,而且开关电源的变压器体积比串联稳压型电源的要小得多,电源电路比较整洁,整机重量也有所下降,所以,现在的LED驱动电源
关键字: LED 驱动电源 开关电源
LED驱动电源是把电源供应转换为特定的电压电流以驱动LED发光的电压转换器,通常情况下:LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: LED 隧道灯 驱动电源
