当前位置:首页 > 电源 > 电源
[导读]LIBRARY IEEE;USE IEEE.Std_logic_1164.ALL;USE IEEE.Std_logic_unsigned.All;USE IEEE.Std_logic_arith.All;ENTITY Dccount ISPort (Clk : IN STD_LOGIC;AI : IN STD_LO
LIBRARY IEEE;
ENTITY Dccount IS
Port (
Clk : IN STD_LOGIC;
AI : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
CO : Out STD_LOGIC_VECTOR(3 DOWNTO 0);
Pulse: IN STD_LOGIC;
DriverA,DriverB: OUT STD_LOGIC;
S : OUT STD_LOGIC_VECTOR(6 DOWNTO 0);
P : OUT STD_LOGIC_VECTOR(5 DOWNTO 0);
Sp : Out STD_LOGIC);
END Dccount;
ARCHITECTURE A OF Dccount IS
SIGNAL F: STD_LOGIC_VECTOR(5 Downto 0);
SIGNAL F_hz: STD_LOGIC;
SIGNAL OSC: STD_LOGIC;
SIGNAL OSC1: STD_LOGIC;
SIGNAL C: STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL A: STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL CODE: STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL Bcd:STD_LOGIC_VECTOR(23 Downto 0);
SIGNAL COUNT:STD_LOGIC_VECTOR(23 Downto 0);
SIGNAL SUM: STD_LOGIC_VECTOR(4 DOWNTO 0);
SIGNAL D: STD_LOGIC_VECTOR(3 DOWNTO 0):=“0000”;
SIGNAL Ind_coil: STD_LOGIC_VECTOR(3 Downto 0) := “0001”;
SIGNAL Hz:STD_LOGIC;
SIGNAL Spo: STD_LOGIC;
SIGNAL SW:STD_LOGIC;
SIGNAL KEY:STD_LOGIC;
SIGNAL DRA,DRB:STD_LOGIC;
BEGIN
DRIVERA《=DRA;
DRIVERB《=DRB;
P(5 Downto 0) 《= F(5 Downto 0);
CO(3 DOWNTO 0) 《=C(3 DOWNTO 0);
A (3 DOWNTO 0)《=AI(3 DOWNTO 0);
SP《=SPO;
-----------------Div------------------------
PROCESS(OSC)
VARIABLE D_ff: STD_LOGIC_VECTOR(20 Downto 0);
VARIABLE DELAY: STD_LOGIC_VECTOR(23 DOWNTO 0);
BEGIN
WAIT UNTIL Clk = ‘’1‘’;
IF D_ff(20 Downto 0) 》= 2E6 THEN
D_ff(20 Downto 0) := “000000000000000000000”;
ELSE
D_ff(20 Downto 0) := D_ff + 1;
END IF;
F_hz 《= Not D_ff(6);
OSC 《= Not D_ff(10);
OSC1 《= Not D_ff(17);
IF DELAY》=500000 THEN
DELAY:=“000000000000000000000000”;HZ《=NOT Hz;
ELSE DELAY:=DELAY+1;
END IF;
END PROCESS ;
PROCESS (F_HZ,OSC,OSC1,HZ,PULSE)
VARIABLE B: STD_LOGIC;
VARIABLE INT: STD_LOGIC;
VARIABLE Data: STD_LOGIC_VECTOR(3 DOWNTO 0);
VARIABLE UP: STD_LOGIC_VECTOR(2 DOWNTO 0);
VARIABLE ST:STD_LOGIC_VECTOR(2 DOWNTO 0);
VARIABLE Seq: STD_LOGIC_VECTOR(1 DOWNTO 0);
VARIABLE Sound: STD_LOGIC_VECTOR(1 DOWNTO 0);
VARIABLE STOP: STD_LOGIC;
VARIABLE DirecTIon: STD_LOGIC;
BEGIN
---------------7seg Scan-------------------------------
IF (F_HZ=‘’1‘’ AND F_HZ‘’EVENT) THEN
IF ST(2 DOWNTO 0)= “101” THEN
ST(2 DOWNTO 0):=“000” ;
ELSE ST(2 DOWNTO 0):=ST(2 DOWNTO 0)+1;
END IF;
END IF;
IF (OSC = ‘’1‘’ And OSC‘’EVENT) THEN
If A=“1111” Then
IF Seq=“11” Then Seq:=“00” ;
Else Seq:=Seq+1;
End If;
Else Seq:=Seq;
End If;
IF Seq=“00” Then C(3 DOWNTO 0)《=“1110” ;
Elsif Seq=“01” Then C(3 DOWNTO 0)《=“1101” ;
Elsif Seq=“10” Then C(3 DOWNTO 0)《=“1011” ;
Elsif Seq=“11” Then C(3 DOWNTO 0)《=“0111” ;
End If;
End If;
IF A=“1111” THEN INT:=‘’0‘’;
ELSE INT:=‘’1‘’;
END IF;
IF (HZ‘’EVENT AND HZ=‘’1‘’) THEN
IF STOP=‘’1‘’ THEN UP:=UP+1;
ELSE UP:=“000”;
END IF;
END IF;
IF KEY=‘’1‘’ AND COUNT/=0 THEN
IF DIRECTION=‘’0‘’ THEN DRA《=‘’1‘’;DRB《=‘’0‘’;STOP:=‘’0‘’;
ELSE DRA《=‘’0‘’;DRB《=‘’1‘’;STOP:=‘’0‘’;
END IF;
ELSIF KEY=‘’1‘’ AND COUNT=0 THEN STOP:=‘’1‘’;
ELSIF STOP=‘’1‘’ AND UP《“110” THEN DRA《=NOT DRA ;DRB《=NOT DRB;
ELSE DRA《=‘’0‘’;DRB《=‘’0‘’;STOP:=‘’0‘’;
END IF;
IF (OSC1‘’EVENT AND OSC1=‘’1‘’) THEN B:=(INT And (B And INT) );
----------------Direction Choice-----------------------
IF SW=‘’0‘’ AND B=‘’1‘’ AND Data(3 DOWNTO 0)=“1010” THEN
BCD(23 DOWNTO 0)《=BCD(23 DOWNTO 0);B:=‘’0‘’;Direction:=‘’1‘’;
ELSIF SW=‘’0‘’ AND B=‘’1‘’ AND Data(3 DOWNTO 0)=“1011” THEN
BCD(23 DOWNTO 0)《=BCD(23 DOWNTO 0);B:=‘’0‘’;Direction:=‘’0‘’;
------------------KEY LOCK ON/OFF------------------------------------
ELSIF B=‘’1‘’ AND Data(3 DOWNTO 0)=“1100” THEN
BCD《=BCD;B:=‘’0‘’;SW《=NOT SW;
-------------------BACK-------------------------------
ELSIF SW=‘’0‘’ AND B=‘’1‘’ AND Data(3 DOWNTO 0)=“1101” THEN
BCD(23 DOWNTO 0)《=(“0000” & Bcd(23 Downto 4) );B:=‘’0‘’;
-------------------CLEAR---------------------------------
ELSIF B=‘’1‘’ AND Data(3 DOWNTO 0)=“1110” THEN
BCD《=“000000000000000000000000” ;B:=‘’0‘’;SW《=‘’0‘’;
------------------DOWNCOUNT 0 ------------------------------------
ELSIF BCD=0 AND KEY=‘’1‘’ THEN SW《=‘’0‘’;KEY《=‘’0‘’;BCD《=BCD;
ELSIF SW=‘’1‘’ AND KEY=‘’1‘’ AND DATA(3 DOWNTO 0)/=“1110” THEN BCD《=COUNT;
ELSIF SW=‘’1‘’ AND DATA(3 DOWNTO 0)=“1110” THEN SW《=‘’0‘’;
BCD《=“000000000000000000000000”;KEY《=‘’0‘’;
-------------------ENTER------------------------------
ELSIF SW=‘’0‘’ AND B=‘’1‘’ AND Data(3 DOWNTO 0)=“1111” AND BCD/=0 THEN
B:=‘’0‘’;SW《=‘’1‘’;KEY《=‘’1‘’;
ELSIF SW=‘’0‘’ AND B=‘’1‘’ AND Data(3 DOWNTO 0)=“1111” AND BCD=0 THEN
BCD《=BCD;B:=‘’0‘’;SW《=‘’0‘’;KEY《=‘’0‘’;
----------------------NUMBER SHIFT---------------------------
ELSIF SW=‘’0‘’ AND B=‘’1‘’ THEN Bcd(23 Downto 0)《= Bcd(19 Downto 0) & DATA(3 DOWNTO 0);B:=‘’0‘’;
Elsif INT=‘’0‘’ Then Bcd《=Bcd;
B:=‘’1‘’;
END IF;
END IF;
SUM(1 DOWNTO 0)《= Seq;
Sum(4 Downto 2)《=Code;
---------------------SOUND-----------------------------
If (Osc‘’Event And Osc=‘’1‘’) Then
If INT=‘’1‘’ AND SW=‘’0‘’ Then Sound:=Sound+1;Spo《=Sound(1) ;
Else Spo《=‘’0‘’;
End If;
End If;
---------------------------DOWNCOUNT--------------------
IF SW=‘’0‘’ THEN COUNT《=BCD;
ELSE
If (PULSE = ‘’1‘’ And PULSE‘’EVENT) THEN
----------------------------1---------------------------------------------------
IF COUNT(3 DOWNTO 0)= 0 AND COUNT(23 DOWNTO 4)》=1 THEN
COUNT(3 DOWNTO 0) 《=“1001” ;
ELSE COUNT(3 DOWNTO 0) 《= COUNT(3 DOWNTO 0)-1;
END IF;
----------------------------2---------------------------------------------------------
IF COUNT(7 DOWNTO 4)= 0 AND COUNT(23 DOWNTO 8)》=1 AND COUNT(3 DOWNTO 0)=0 THEN
COUNT(7 DOWNTO 4) 《= “1001” ;
ELSIF COUNT(3 DOWNTO 0)=0 AND COUNT(23 DOWNTO 4)》=1 THEN
COUNT(7 DOWNTO 4) 《=COUNT(7 DOWNTO 4 )-1;
END IF;
----------------------------3-------------------------------------------------------
IF COUNT(11 DOWNTO 8)= 0 AND COUNT(23 DOWNTO 12)》=1 AND COUNT(7 DOWNTO 0)=0 THEN
COUNT(11 DOWNTO 8) 《=“1001”;
ELSIF COUNT(7 DOWNTO 0)=0 AND COUNT(23 DOWNTO 8)》=1 THEN
COUNT(11 DOWNTO 8) 《=COUNT(11 DOWNTO 8 )-1;
END IF;
---------------------------4--------------------------------------------------------------
IF COUNT(15 DOWNTO 12)= 0 AND COUNT(23 DOWNTO 16)》=1 AND COUNT(11 DOWNTO 0)=0 THEN
COUNT(15 DOWNTO 12) 《=“1001”;
ELSIF COUNT(11 DOWNTO 8)=0 AND COUNT(23 DOWNTO 12)》=1 AND COUNT(7 DOWNTO 0)=0 THEN
COUNT(15 DOWNTO 12) 《=COUNT(15 DOWNTO 12 )-1;
END IF;
-------------------------5------------------------------------------------------------
IF COUNT(19 DOWNTO 16)= 0 AND COUNT(23 DOWNTO 20)》=1 AND COUNT(15 DOWNTO 0)=0 THEN
COUNT(19 DOWNTO 16) 《=“1001”;
ELSIF COUNT(15 DOWNTO 12)=0 AND COUNT(23 DOWNTO 16)》=1 AND COUNT(11 DOWNTO 0)=0 THEN
COUNT(19 DOWNTO 16) 《=COUNT(19 DOWNTO 16 )-1;
END IF;
-------------------------6-------------------------------------------------
IF COUNT(23 DOWNTO 20)= 0 THEN
COUNT(23 DOWNTO 20) 《=“0000”;
ELSIF COUNT(19 DOWNTO 16)=0 AND COUNT(23 DOWNTO 20 )》=1 AND COUNT(15 DOWNTO 0)=0 THEN
COUNT(23 DOWNTO 20) 《=COUNT(23 DOWNTO 20 )-1;
END IF;
END IF;
END IF;
END IF;
------------------7seg Scan---------------------------
CASE ST IS --?@潮
WHEN “000”=》 D(3 DOWNTO 0) 《= Bcd(3 DOWNTO 0) ; F(5 Downto 0)《=“111110”;
WHEN “001”=》 D(3 DOWNTO 0) 《= Bcd(7 DOWNTO 4) ; F(5 Downto 0)《=“111101”;
WHEN “010”=》 D(3 DOWNTO 0) 《= Bcd(11 DOWNTO 8) ; F(5 Downto 0)《=“111011”;
WHEN “011”=》 D(3 DOWNTO 0) 《= Bcd(15 DOWNTO 12) ; F(5 Downto 0)《=“110111”;
WHEN “100”=》 D(3 DOWNTO 0) 《= Bcd(19 DOWNTO 16) ; F(5 Downto 0)《=“101111”;
WHEN “101”=》 D(3 DOWNTO 0) 《= Bcd(23 DOWNTO 20) ; F(5 Downto 0)《=“011111”;
WHEN OTHERS =》 D(3 DOWNTO 0) 《= “1100” ; F(5 Downto 0)《=“111111”;
END CASE;
------------------Key Scan-------------------------
CASE A(3 DOWNTO 0) IS
WHEN“1110” =》 CODE《=“100”;
WHEN“1101” =》 CODE《=“101”;
WHEN“1011” =》 CODE《=“110”;
WHEN“0111” =》 CODE《=“111”;
WHEN OTHERS =》 CODE《=“000”;
End Case;
---------------------Key Table------------------------
CASE SUM(4 DOWNTO 0) IS
WHEN“10000”=》 Data:=“0001”;--0
WHEN“10001”=》 Data:=“0101”;--1
WHEN“10010”=》 Data:=“1001”;--2
WHEN“10011”=》 Data:=“1100”;--3
LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: 驱动电源
在工业自动化蓬勃发展的当下,工业电机作为核心动力设备,其驱动电源的性能直接关系到整个系统的稳定性和可靠性。其中,反电动势抑制与过流保护是驱动电源设计中至关重要的两个环节,集成化方案的设计成为提升电机驱动性能的关键。
关键字: 工业电机 驱动电源
LED 驱动电源作为 LED 照明系统的 “心脏”,其稳定性直接决定了整个照明设备的使用寿命。然而,在实际应用中,LED 驱动电源易损坏的问题却十分常见,不仅增加了维护成本,还影响了用户体验。要解决这一问题,需从设计、生...
关键字: 驱动电源 照明系统 散热
根据LED驱动电源的公式,电感内电流波动大小和电感值成反比,输出纹波和输出电容值成反比。所以加大电感值和输出电容值可以减小纹波。
关键字: LED 设计 驱动电源
电动汽车(EV)作为新能源汽车的重要代表,正逐渐成为全球汽车产业的重要发展方向。电动汽车的核心技术之一是电机驱动控制系统,而绝缘栅双极型晶体管(IGBT)作为电机驱动系统中的关键元件,其性能直接影响到电动汽车的动力性能和...
关键字: 电动汽车 新能源 驱动电源
在现代城市建设中,街道及停车场照明作为基础设施的重要组成部分,其质量和效率直接关系到城市的公共安全、居民生活质量和能源利用效率。随着科技的进步,高亮度白光发光二极管(LED)因其独特的优势逐渐取代传统光源,成为大功率区域...
关键字: 发光二极管 驱动电源 LED
LED通用照明设计工程师会遇到许多挑战,如功率密度、功率因数校正(PFC)、空间受限和可靠性等。
关键字: LED 驱动电源 功率因数校正
在LED照明技术日益普及的今天,LED驱动电源的电磁干扰(EMI)问题成为了一个不可忽视的挑战。电磁干扰不仅会影响LED灯具的正常工作,还可能对周围电子设备造成不利影响,甚至引发系统故障。因此,采取有效的硬件措施来解决L...
关键字: LED照明技术 电磁干扰 驱动电源
开关电源具有效率高的特性,而且开关电源的变压器体积比串联稳压型电源的要小得多,电源电路比较整洁,整机重量也有所下降,所以,现在的LED驱动电源
关键字: LED 驱动电源 开关电源
LED驱动电源是把电源供应转换为特定的电压电流以驱动LED发光的电压转换器,通常情况下:LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: LED 隧道灯 驱动电源
