C#备份和恢复SQL Server数据库
SQLDMO(SQL Distributed Management Objects,SQL分布式管理对象)封装了Microsoft SQL Server数据库中的对象。SQLDMO是Microsoft SQL Server中企业管理器所使用的应用程序接口,所以它可以执行很多功能,其中当然也包括对数据库的备份和恢复。
SQLDMO由Microsoft SQL Server自带的SQLDMO.dll提供,由于SQLDMO.dll是一个COM对象(有关COM的概念,请参看我的COM与COM+技术那篇文章),所以大家在用之前必须在.Net项目中添加对它的引用。
下面是用C#语言书写的用于Microsoft SQL Server数据库备份和恢复的类:
public sealed class DbOper
/// DbOper类的构造函数
///作者:Shadow
private DbOper()
/// 数据库备份
public static void DbBackup()
SQLDMO.Backup oBackup = new SQLDMO.BackupClass();
SQLDMO.SQLServer oSQLServer = new SQLDMO.SQLServerClass();
try
oSQLServer.LoginSecure = false;
oSQLServer.Connect("localhost", "sa", "1234");
oBackup.Action = SQLDMO.SQLDMO_BACKUP_TYPE.SQLDMOBackup_Database;
oBackup.Database = "Northwind";
oBackup.Files = @"d:/Northwind.bak";
oBackup.BackupSetName = "Northwind";
oBackup.BackupSetDescription = "数据库备份";
oBackup.Initialize = true;
oBackup.SQLBackup(oSQLServer);
catch
throw;
finally
oSQLServer.DisConnect();
/// 数据库恢复
public static void DbRestore()
SQLDMO.Restore oRestore = new SQLDMO.RestoreClass();
try
oRestore.Action = SQLDMO.SQLDMO_RESTORE_TYPE.SQLDMORestore_Database;
oRestore.Database = "Northwind";
oRestore.Files = @"d:/Northwind.bak";
oRestore.FileNumber = 1;
oRestore.ReplaceDatabase = true;
oRestore.SQLRestore(oSQLServer);
catch
throw;
finally
