PHP session 防止重复登录的妙招
时间:2018-10-18 16:34:01
[导读]zhclass.phpcon = mysql_connect("localhost", "root", "root");
mysql_query("set names 'utf8'")
zhclass.php
mysql_query("set names 'utf8'");
if (! $this->con) {
die('连接服务器失败: ' . mysql_error());
} else {
mysql_select_db("mytest", $this->con);
function logging($id, $mm) // 登录
$this->zh = $id;
$this->mm = $mm;
if (! $this->checkZh()) {
return false;
// 判断字段是否存在
$result = mysql_query("SELECT * FROM teacher WHERE id=$id");
if (mysql_num_rows($result) != 0) {
$row = mysql_fetch_array($result);
$m_mima = $row['mima'];
$name = $row['name'];
if ($mm == $m_mima) {
echo "登录成功";
return true;
} else {
echo "密码错误";
} else {
echo "登录失败";
return false;
function GetZhSession($zh)
if($this->checkZh2($zh)==false)
return null;
$result = mysql_query("SELECT * FROM teacher WHERE id=$zh");
if(mysql_num_rows($result)>0)
$session = $row['sec'];
return $session;
}else {
return null;
function SetZhSession($zh,$sec)
return false;
if (mysql_query("UPDATE teacher SET sec='$sec' WHERE id=$zh")==false)
return false;
return true;
function _ChangeUserName($mid, $mm, $newName)
$this->zh = $mid;
$this->mm = $mm;
echo "账号不存在!";
return false;
if (! $this->logging($mid, $mm)) {
return false;
echo $newName . "," . $mm;
// 传过来的是字符串 但是数据库不识别 加上两个单引号转为字符串 '$newName'
$ret = mysql_query("UPDATE teacher SET name='$newName' WHERE id=$mid");
if (! $ret) {
echo " 无法修改用户昵称 ";
public function Reg($zh, $mima, $nichen)
$this->zh = $zh;
$this->mm = $mima;
if ($this->checkZh()) {
echo "账号已存在";
return;
if (mysql_query("INSERT INTO teacher (name,id,mima) VALUES ('$nichen',$zh,'$mima')") == false) {
echo "注册失败";
} else {
echo "注册成功";
public function __destruct() // 析构函数销毁数据库连接
mysql_close($this->con);
?>index.php
GetZhSession($_SESSION["VVV"])==session_id())
echo "已经登录";
}else {
echo "登录过期!!!";
return ;
} else {
// 未登录
echo "log";
return ;
?>denglu.php
type==0){
if( $pobj->logging($obj->id, $obj->pwd) ==true)
$_SESSION["VVV"] = $obj->id;
echo $_SESSION["VVV"];
$pobj->SetZhSession($obj->id,session_id() );
echo "登陆成功";
}else{
echo "未定义";
?>~~~~~~~~~~~~~~~~~~~~使用xhr post登录~~~~~~~~~~~~~~~~~~~~~~~~~~~
使用post登录 ,确定登录后再执行其他post,防止异步获取多个session
function logging()
var x = new XMLHttpRequest();
x.onreadystatechange =function()
if(x.readyState == 4) {
if(x.status == 200) {
console.log("The server replied with: " + x.responseText);
txt.text = x.responseText;
var xxx = new Object;
xxx.id="289672082";
xxx.pwd = '12345';
xxx.type=0;
var pcode= JSON.stringify(xxx);
x.open("POST","http://192.168.0.105/mycode/Test/denglu.php",true);
//post请求要自己设置请求头
x.setRequestHeader("Content-Type","application/x-www-form-urlencoded");
x.send("code="+pcode);
}如果用户没有登录尝试其他行为,在返回值中要求用户登录:
function _PHP_TEST(async)
if(x.responseText=="log")
console.log("需要登录");
logging();
}else{
x.open("POST","http://192.168.0.105/mycode/Test/index.php",async);
//post请求要自己设置请求头
x.send(null);
}~~~~~~~~~~~~~~~~使用Qt C++登录~~~~~~~~~~~~~~~~~~~~~~~~~~
QmlClass::QmlClass(QObject *parent) : QObject(parent)
QByteArray data="";
m_netManger = new QNetworkAccessManager(this);
QNetworkRequest network_request;
//设置头信息
network_request.setHeader(QNetworkRequest::ContentTypeHeader, "application/x-www-form-urlencoded");
network_request.setHeader(QNetworkRequest::ContentLengthHeader, data.length());
//设置url
network_request.setUrl(QUrl("http://localhost/mycode/Test/index.php"));
//发送请求 获取一些关键数据 前提是已近登录
QNetworkReply *reply2=m_netManger->post(network_request, data);
connect(reply2,&QNetworkReply::readyRead,this,[=](){
QString t =reply2->readAll();
if(t=="log" && t.length()>0)
qDebug()<Loging();
qDebug()<<" POST返回"<post(network_request, data);
qDebug()<<"登录返回值"<<t;
return true;
