当前位置:首页 > > 充电吧
[导读]如果既不想写回调函数,又想避免sqlite3_get_table之后麻烦的一维数组遍历,那么利用sqlite3_prepare_v2执行sql select语句,让后sqlite3_step遍历sel
如果既不想写回调函数,又想避免sqlite3_get_table之后麻烦的一维数组遍历,那么利用sqlite3_prepare_v2执行sql select语句,让后sqlite3_step遍历select执行的返回结果是一个非常方便的solution. 当然,你必须要明白sqlite3_prepare_v2不仅仅能够执行table的query selection,也能方便地进行sql Delete, Insert, Update等其他一些操作。它能帮你把sql语句的执行操作变的更加优雅。
[cpp] view plaincopy int sqlite3_prepare_v2(     sqlite3 *db,            /* Database handle */     const char *zSql,       /* SQL statement, UTF-8 encoded */     int nByte,              /* Maximum length of zSql in bytes. */     sqlite3_stmt **ppStmt,  /* OUT: Statement handle */     const char **pzTail     /* OUT: Pointer to unused portion of zSql */   );   [cpp] view plaincopy int sqlite3_step(sqlite3_stmt*);   下面以一段iOS中的selection查询为例说明二者的用法:
[cpp] view plaincopy -(void)InitializeFilesTable   {       const char * query = "SELECT * FROM [FileObjects]";       sqlite3_stmt * stmt;       int result = sqlite3_prepare_v2(mDatabase, query, -1, &stmt, NULL);       if(SQLITE_OK != result)       {           sqlite3_finalize(stmt);           // The table has not been created. Most likely, this is the first time we create the database.           // Therefore, create all tables in it           char * sql = "Create TABLE [FileObjects] ([FileId] VARCHAR(128),[FileExt] VARCHAR(128), [FileName] VARCHAR(128), [FileUrl] VARCHAR(128), [FileType] INT  );"; // NOXLATE           char * errMsg;           result = sqlite3_exec(mDatabase, sql, NULL, NULL, &errMsg);       }       else       {           // Select returns OK, initialize the memory model from the result           NSMutableDictionary * files = [NSMutableDictionary new];           while(sqlite3_step(stmt) == SQLITE_ROW)           {               FileObject * file = [FileObject new];                              const char * str = (const char *)sqlite3_column_text(stmt, 0);               file.FileId = str? [[NSString alloc] initWithUTF8String:str] : @"";                              str = (const char *)sqlite3_column_text(stmt, 1);               file.FileExt = str? [[NSString alloc] initWithUTF8String:str] : @"";                              str = (const char *)sqlite3_column_text(stmt, 2);               file.FileName = str? [[NSString alloc] initWithUTF8String:str] : @"";                              str = (const char *)sqlite3_column_text(stmt, 3);               file.FileUrl = str? [[NSString alloc] initWithUTF8String:str] : @"";                              file.FileType = sqlite3_column_int(stmt, 4);                              [files setObject:file forKey:file.FileId];           }                      sqlite3_finalize(stmt);           [mFiles setDictionary:files];       }   }   这其中包括对sqlite3_exec的调用。sqlite3_exec可以执行任何sql语句,包括事务("BEGIN TRANSACTION")、回滚("ROLLBACK")和提交("COMMIT")等等。
LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: 驱动电源
在工业自动化蓬勃发展的当下,工业电机作为核心动力设备,其驱动电源的性能直接关系到整个系统的稳定性和可靠性。其中,反电动势抑制与过流保护是驱动电源设计中至关重要的两个环节,集成化方案的设计成为提升电机驱动性能的关键。
关键字: 工业电机 驱动电源
LED 驱动电源作为 LED 照明系统的 “心脏”,其稳定性直接决定了整个照明设备的使用寿命。然而,在实际应用中,LED 驱动电源易损坏的问题却十分常见,不仅增加了维护成本,还影响了用户体验。要解决这一问题,需从设计、生...
关键字: 驱动电源 照明系统 散热
根据LED驱动电源的公式,电感内电流波动大小和电感值成反比,输出纹波和输出电容值成反比。所以加大电感值和输出电容值可以减小纹波。
关键字: LED 设计 驱动电源
电动汽车(EV)作为新能源汽车的重要代表,正逐渐成为全球汽车产业的重要发展方向。电动汽车的核心技术之一是电机驱动控制系统,而绝缘栅双极型晶体管(IGBT)作为电机驱动系统中的关键元件,其性能直接影响到电动汽车的动力性能和...
关键字: 电动汽车 新能源 驱动电源
在现代城市建设中,街道及停车场照明作为基础设施的重要组成部分,其质量和效率直接关系到城市的公共安全、居民生活质量和能源利用效率。随着科技的进步,高亮度白光发光二极管(LED)因其独特的优势逐渐取代传统光源,成为大功率区域...
关键字: 发光二极管 驱动电源 LED
LED通用照明设计工程师会遇到许多挑战,如功率密度、功率因数校正(PFC)、空间受限和可靠性等。
关键字: LED 驱动电源 功率因数校正
在LED照明技术日益普及的今天,LED驱动电源的电磁干扰(EMI)问题成为了一个不可忽视的挑战。电磁干扰不仅会影响LED灯具的正常工作,还可能对周围电子设备造成不利影响,甚至引发系统故障。因此,采取有效的硬件措施来解决L...
关键字: LED照明技术 电磁干扰 驱动电源
开关电源具有效率高的特性,而且开关电源的变压器体积比串联稳压型电源的要小得多,电源电路比较整洁,整机重量也有所下降,所以,现在的LED驱动电源
关键字: LED 驱动电源 开关电源
LED驱动电源是把电源供应转换为特定的电压电流以驱动LED发光的电压转换器,通常情况下:LED驱动电源的输入包括高压工频交流(即市电)、低压直流、高压直流、低压高频交流(如电子变压器的输出)等。
关键字: LED 隧道灯 驱动电源
