自制日期选择器(datepicker)
在网上看过很多关于datepicker的列子,效果就是我想要的,但界面却和我的项目不同,因此在网上的例子上做做手脚,改变下外观,先说下改动的地方,再将代码放上去。
1、主要改动关键是在WheelView类:protected void onDraw(Canvas canvas)方法中,drawCenterRect(canvas)的位置放置
@Override
protected void onDraw(Canvas canvas) {
super.onDraw(canvas);
if (itemsLayout == null) {
if (itemsWidth == 0) {
calculateLayoutWidth(getWidth(), MeasureSpec.EXACTLY);
} else {
createLayouts(itemsWidth, labelWidth);
drawCenterRect(canvas); // 放在此处,字在背景色上
if (itemsWidth > 0) {
canvas.save();
// Skip padding space and hide a part of top and bottom items
canvas.translate(PADDING, -ITEM_OFFSET);
drawItems(canvas);
drawValue(canvas);
canvas.restore();
// drawCenterRect(canvas);// 放在此处,字在背景色下
drawShadows(canvas);
}2、在wheel_val.xml文件中设置选中项背景色
下面公布下代码:
NumericWheelAdapter类:
* Copyright 2010 Yuri Kanivets
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
package com.lakala.pay.easycashregisterphone2.view.datepicker;
* Numeric Wheel adapter.
public class NumericWheelAdapter implements WheelAdapter {
/** The default min value */
public static final int DEFAULT_MAX_VALUE = 9;
/** The default max value */
private static final int DEFAULT_MIN_VALUE = 0;
// Values
private int minValue;
private int maxValue;
// format
private String format;
* Default constructor
public NumericWheelAdapter() {
this(DEFAULT_MIN_VALUE, DEFAULT_MAX_VALUE);
* Constructor
* @param minValue the wheel min value
* @param maxValue the wheel max value
public NumericWheelAdapter(int minValue, int maxValue) {
this(minValue, maxValue, null);
* Constructor
* @param format the format string
public NumericWheelAdapter(int minValue, int maxValue, String format) {
this.minValue = minValue;
this.maxValue = maxValue;
this.format = format;
public String getItem(int index) {
if (index >= 0 && index < getItemsCount()) {
int value = minValue + index;
return format != null ? String.format(format, value) : Integer.toString(value);
return null;
public int getItemsCount() {
return maxValue - minValue + 1;
public int getMaximumLength() {
int max = Math.max(Math.abs(maxValue), Math.abs(minValue));
int maxLen = Integer.toString(max).length();
if (minValue < 0) {
maxLen++;
return maxLen;
OnWheelChangedListener类:
* Wheel changed listener interface.
*The currentItemChanged() method is called whenever current wheel positions is changed:
*New Wheel position is set
*Wheel view is scrolled
public interface OnWheelChangedListener {
* Callback method to be invoked when current item changed
* @param wheel the wheel view whose state has changed
* @param oldValue the old value of current item
* @param newValue the new value of current item
void onChanged(WheelView wheel, int oldValue, int newValue);
OnWheelScrollListener类:
* Wheel scrolled listener interface.
public interface OnWheelScrollListener {
* Callback method to be invoked when scrolling started.
* @param wheel the wheel view whose state has changed.
void onScrollingStarted(WheelView wheel);
* Callback method to be invoked when scrolling ended.
void onScrollingFinished(WheelView wheel);
WheelAdapter类:
public interface WheelAdapter {
* Gets items count
* @return the count of wheel items
public int getItemsCount();
* Gets a wheel item by index.
* @param index the item index
* @return the wheel item text or null
public String getItem(int index);
* Gets maximum item length. It is used to determine the wheel width.
* If -1 is returned there will be used the default wheel width.
* @return the maximum item length or -1
public int getMaximumLength();
WheelView类:
* Android Wheel Control.
* https://code.google.com/p/android-wheel/
package kankan.wheel.widget;
import java.util.LinkedList;
import java.util.List;
import org.unism.wang.R;
import android.content.Context;
import android.graphics.Canvas;
import android.graphics.Paint;
import android.graphics.Rect;
import android.graphics.drawable.Drawable;
import android.graphics.drawable.GradientDrawable;
import android.graphics.drawable.GradientDrawable.Orientation;
import android.os.Handler;
import android.os.Message;
import android.text.Layout;
import android.text.StaticLayout;
import android.text.TextPaint;
import android.util.AttributeSet;
import android.util.FloatMath;
import android.view.GestureDetector;
import android.view.GestureDetector.SimpleOnGestureListener;
import android.view.MotionEvent;
import android.view.View;
import android.view.animation.Interpolator;
import android.widget.Scroller;
* Numeric wheel view.
* @author Yuri Kanivets
public class WheelView extends View {
* Scrolling duration
* 滚动持续时间(毫秒)
private static final int SCROLLING_DURATION = 400;
* Minimum delta for scrolling
* 滚动的最小差值
private static final int MIN_DELTA_FOR_SCROLLING = 1;
* Current value & label text color
* 当前选中项 的 文字 的 颜色
private static final int VALUE_TEXT_COLOR = 0xFFFFFFFF;
* Items text color
* 选项 的 文字 的 颜色
private static final int ITEMS_TEXT_COLOR = 0xFF000000;
* Top and bottom shadows colors
* 顶部和底部阴影 的 颜色
* 选择器 顶部和底部颜色是渐变的,这里指定一个渐变色的数组
private static final int[] SHADOWS_COLORS = new int[] { 0xFFFFFFFF,
0x00EEEED5, 0x00EEEED5 };
* Additional items height (is added to standard text item height)
* 附加项的高度项的高度 (单位应该是dp)
* 从后面getDesiredHeight() 函数看出,这个值应该是平分给每一个选项的。
* 类似于设置行距吧,不过这是一个总和,也就是有5个可见项,那么每个可见项的附加高就是 ADDITIONAL_ITEM_HEIGHT/5
private static final int ADDITIONAL_ITEM_HEIGHT = 15;
* Text size
* 字号
private static final int TEXT_SIZE = 24;
* Top and bottom items offset (to hide that)
* 这个是选项在顶部和底部被抵消的值。
* 怎么解释呢~ 其实试一下就知道了,
* 比如说在picker中显示的五项(中间那个是选中的),剩余4是没选中的。
* 在没选中的这4项中,位于顶部和底部的项,会用阴影遮挡(遮挡一部分,这样用户就明白是需要滑动操作了)
* 这里设定的值,就是指定遮挡的size,这里的默认值 TEXT_SIZE / 5 是遮挡了1/5的字号 (那么单位也应该是sp吧)
private static final int ITEM_OFFSET = TEXT_SIZE / 5;
* Additional width for items layout
* 附加项空间? 不理解~~还是试试吧
* 应该是项的宽,这个属性应该是受制于外边区域的, 设置的太宽里面的文字显示会出问题
* 具体影响 有待进一步实验证明
private static final int ADDITIONAL_ITEMS_SPACE = 10;
* Label offset
* 标签抵消 (作用未知) 用1,8,和800 三个值实验(8是默认值) 效果是一样的。
private static final int LABEL_OFFSET = 8;
* Left and right padding value
* 填充
* 这个选项的内部填充,如果选项是个TextView的话,那这里设置的即是TextView的填充
* =。=!后面代码还米有看,item是啥我也不知道
private static final int PADDING = 10;
* Default count of visible items
* 默认可见项的数目。就是picker中显示几项
private static final int DEF_VISIBLE_ITEMS = 5;
// Wheel Values
* Wheel Values
* 适配器,items就通过适配器来提供的吧
private WheelAdapter adapter = null;
* Wheel Values
* 当前项
private int currentItem = 0;
// Widths
* Widths
* 做了实验 把值设为100 没有任何变化
private int itemsWidth = 0;
* Widths
* 也做了实验 把值设为100 没有任何变化
private int labelWidth = 0;
// Count of visible items
* Count of visible items
* 可见项目的条数
private int visibleItems = DEF_VISIBLE_ITEMS;
// Item height
* Item height
* 是item的高
private int itemHeight = 0;
// Text paints
* Text paints
* 选中文本的颜色
private TextPaint itemsPaint;
* Text paints
* 未选中文本的颜色
private TextPaint valuePaint;
// Layouts
* Layouts
* 选项 的 布局
private StaticLayout itemsLayout;
* Layouts
* 标签 的 布局
private StaticLayout labelLayout;
* Layouts
* 选中项 的 布局
private StaticLayout valueLayout;
// Label & background
* Label & background
* 标签
private String label;
* 中间的几何体
* 选中区域的背景
private Drawable centerDrawable;
// Shadows drawables
* Shadows drawables
* 上边 和 底部 的阴影部分的背景资源
private GradientDrawable topShadow;
private GradientDrawable bottomShadow;
// Scrolling
* Scrolling
* 执行滚动?
private boolean isScrollingPerformed;
* Scrolling
* 滚动抵消?
private int scrollingOffset;
// Scrolling animation
* Scrolling animation
* 手势检测器
private GestureDetector gestureDetector;
* 卷轴
private Scroller scroller;
* 最后的 卷轴Y
private int lastScrollY;
// Cyclic
* Cyclic
* 是否循环
boolean isCyclic = false;
// Listeners
* Listeners
* 控件改变监听器的 集合
private ListchangingListeners = new LinkedList();
* Listeners
* 控件滚动监听器的 集合
private ListscrollingListeners = new LinkedList();
* Constructor
* 构造器 并实例了手势检测器 和 卷轴
public WheelView(Context context, AttributeSet attrs, int defStyle) {
super(context, attrs, defStyle);
initData(context);
* Constructor
public WheelView(Context context, AttributeSet attrs) {
super(context, attrs);
initData(context);
* Constructor
public WheelView(Context context) {
super(context);
initData(context);
* Initializes class data
* @param context the context
* 数据初始化
* 就是把手势检测器 和 卷轴类 实例了
* 这个方法在所有的构造器中都被调用了
private void initData(Context context) {
gestureDetector = new GestureDetector(context, gestureListener);
gestureDetector.setIsLongpressEnabled(false); //这个没看出来有什么用,不设置,或设置成true都不影响效果
scroller = new Scroller(context);
* Gets wheel adapter
* @return the adapter
* 获得适配器
public WheelAdapter getAdapter() {
return adapter;
* Sets wheel adapter
* @param adapter the new wheel adapter
* 设置适配器
* 还会界面进行了重绘
public void setAdapter(WheelAdapter adapter) {
this.adapter = adapter;
invalidateLayouts();
invalidate();
* Set the the specified scrolling interpolator
* @param interpolator the interpolator
* 作用也是设置 卷轴的吧,是通过动画插补器来实例 卷轴对象
public void setInterpolator(Interpolator interpolator) {
scroller.forceFinished(true);
scroller = new Scroller(getContext(), interpolator);
* Gets count of visible items
* @return the count of visible items
* 获得可见项的条数
public int getVisibleItems() {
return visibleItems;
* Sets count of visible items
* @param count
* the new count
* 设置可见项的条数 并重绘view
public void setVisibleItems(int count) {
visibleItems = count;
invalidate();
* Gets label
* @return the label
* 获得标签
public String getLabel() {
return label;
* Sets label
* @param newLabel
* the label to set
* 设置标签
public void setLabel(String newLabel) {
if (label == null || !label.equals(newLabel)) {
label = newLabel;
labelLayout = null;
invalidate();
* Adds wheel changing listener
* @param listener the listener
* 添加控件改变监听器
public void addChangingListener(OnWheelChangedListener listener) {
changingListeners.add(listener);
* Removes wheel changing listener
* 移除控件改变监听器
public void removeChangingListener(OnWheelChangedListener listener) {
changingListeners.remove(listener);
* Notifies changing listeners
* @param oldValue the old wheel value
* @param newValue the new wheel value
* 通知 改变监听器,
* 循环 控件改变监听器集合, 并依次调用它们的onChenge方法
protected void notifyChangingListeners(int oldValue, int newValue) {
for (OnWheelChangedListener listener : changingListeners) {
listener.onChanged(this, oldValue, newValue);
* Adds wheel scrolling listener
* 添加控件滚动监听器
public void addScrollingListener(OnWheelScrollListener listener) {
scrollingListeners.add(listener);
* Removes wheel scrolling listener
* 移除控件滚动监听器
public void removeScrollingListener(OnWheelScrollListener listener) {
scrollingListeners.remove(listener);
* Notifies listeners about starting scrolling
* 通知控件滚动监听器调用开始滚动的方法
protected void notifyScrollingListenersAboutStart() {
for (OnWheelScrollListener listener : scrollingListeners) {
listener.onScrollingStarted(this);
* Notifies listeners about ending scrolling
* 通知控件滚动监听器调用结束滚动的方法
protected void notifyScrollingListenersAboutEnd() {
listener.onScrollingFinished(this);
* Gets current value
* @return the current value
* 返回当前项的索引
public int getCurrentItem() {
return currentItem;
* Sets the current item. Does nothing when index is wrong.
* @param animated the animation flag
* 设置当前项 如果输入错误的索引,则控件什么都不会做哟
* 第二个参数是设置是否使用滚动动画的
public void setCurrentItem(int index, boolean animated) {
if (adapter == null || adapter.getItemsCount() == 0) {
return; // throw?
if (index < 0 || index >= adapter.getItemsCount()) {
if (isCyclic) {
while (index < 0) {
index += adapter.getItemsCount();
index %= adapter.getItemsCount();
} else{
return; // throw?
if (index != currentItem) {
if (animated) {
scroll(index - currentItem, SCROLLING_DURATION);
} else {
int old = currentItem;
currentItem = index;
notifyChangingListeners(old, currentItem);
invalidate();
* Sets the current item w/o animation. Does nothing when index is wrong.
* 设置当前选中项,默认是不启动动画的
public void setCurrentItem(int index) {
setCurrentItem(index, false);
* Tests if wheel is cyclic. That means before the 1st item there is shown the last one
* @return true if wheel is cyclic
* 是否循环显示
public boolean isCyclic() {
return isCyclic;
* Set wheel cyclic flag
* @param isCyclic the flag to set
* 设置是否循环显示
public void setCyclic(boolean isCyclic) {
this.isCyclic = isCyclic;
invalidate();
* Invalidates layouts
* 重绘布局
* 方法将 选项布局itemsLayout 和 选中项布局 valueLayout 赋值为null
* 同事将 滚动抵消?scrollingOffset 设置为0
* (这个scrollingOffset 还没搞明白做什么用)
private void invalidateLayouts() {
itemsLayout = null;
valueLayout = null;
scrollingOffset = 0;
* Initializes resources
* 初始化源
* 这个方法是这样的, 判断前面定义的画笔、背景资源等私有属性的值,如果是null就重新从静态常量中取值,并付给响应的属性。
* 如果这些必要属性为空的话,这个函数应该起到了初始化的作用
private void initResourcesIfNecessary() {
if (itemsPaint == null) {
itemsPaint = new TextPaint(Paint.ANTI_ALIAS_FLAG
| Paint.FAKE_BOLD_TEXT_FLAG);
//itemsPaint.density = getResources().getDisplayMetrics().density;
itemsPaint.setTextSize(TEXT_SIZE);
if (valuePaint == null) {
valuePaint = new TextPaint(Paint.ANTI_ALIAS_FLAG
| Paint.FAKE_BOLD_TEXT_FLAG | Paint.DITHER_FLAG);
//valuePaint.density = getResources().getDisplayMetrics().density;
valuePaint.setTextSize(TEXT_SIZE);
valuePaint.setShadowLayer(0.1f, 0, 0.1f, 0xFFC0C0C0);
if (centerDrawable == null) {
centerDrawable = getContext().getResources().getDrawable(R.drawable.wheel_val);
if (topShadow == null) {
topShadow = new GradientDrawable(Orientation.TOP_BOTTOM, SHADOWS_COLORS);
if (bottomShadow == null) {
bottomShadow = new GradientDrawable(Orientation.BOTTOM_TOP, SHADOWS_COLORS);
setBackgroundResource(R.drawable.wheel_bg);
* Calculates desired height for layout
* @param layout
* the source layout
* @return the desired layout height
* 获得理想的控件高度,并保证其不低于建议的最小高度
private int getDesiredHeight(Layout layout) {
if (layout == null) {
return 0;
int desired = getItemHeight() * visibleItems - ITEM_OFFSET * 2
- ADDITIONAL_ITEM_HEIGHT;
// Check against our minimum height
desired = Math.max(desired, getSuggestedMinimumHeight());
return desired;
* Returns text item by index
* @return the item or null
* 指定索引,获得选项的文本值(Sring)
* 如果索引超出范围,控件又不是循环的(isCyclic),则返回null
* 如果是循环的情况,方法内部进行了处理,
* 为负数则+count, 然会取余
private String getTextItem(int index) {
return null;
int count = adapter.getItemsCount();
if ((index < 0 || index >= count) && !isCyclic) {
return null;
} else {
while (index < 0) {
index = count + index;
index %= count;
return adapter.getItem(index);
* Builds text depending on current value
* @param useCurrentValue
* @return the text
* 依赖当前项 构建文本
* 获得一个字符串,如果当前项目的索引为5, 可见项目数为3
* 则字符串的值为 getTextItem(3).append("n").getTextItem(4).append("n").getTextItem(5).append("n").getTextItem(6).append("n").getTextItem(7)
* 如果 参数useCurrentValue为false
* 则返回的字符串为 getTextItem(3).append("n").getTextItem(4).append("n").getTextItem(6).append("n").getTextItem(7)
* 如果getTextItem(i)返回null, 则不会向返回值中追加
private String buildText(boolean useCurrentValue) {
StringBuilder itemsText = new StringBuilder();
int addItems = visibleItems / 2 + 1;
for (int i = currentItem - addItems; i <= currentItem + addItems; i++) {
if (useCurrentValue || i != currentItem) {
String text = getTextItem(i);
if (text != null) {
itemsText.append(text);
if (i < currentItem + addItems) {
itemsText.append("n");
return itemsText.toString();
* Returns the max item length that can be present
* @return the max length
* 获得最大的文本长度
* 后面计算控件宽度用的
private int getMaxTextLength() {
WheelAdapter adapter = getAdapter();
if (adapter == null) {
return 0;
int adapterLength = adapter.getMaximumLength();
if (adapterLength > 0) {
return adapterLength;
String maxText = null;
int addItems = visibleItems / 2;
for (int i = Math.max(currentItem - addItems, 0);
i < Math.min(currentItem + visibleItems, adapter.getItemsCount()); i++) {
String text = adapter.getItem(i);
if (text != null && (maxText == null || maxText.length() < text.length())) {
maxText = text;
}//这个循环的范围没看明白呀,起始值不考虑循环吗? 上限为什么是 当前项索引+可见项目数?
return maxText != null ? maxText.length() : 0;
* Returns height of wheel item
* @return the item height
* 获得选项高
private int getItemHeight() {
if (itemHeight != 0) {
return itemHeight;
} else if (itemsLayout != null && itemsLayout.getLineCount() > 2) {
itemHeight = itemsLayout.getLineTop(2) - itemsLayout.getLineTop(1);
return itemHeight;
}//如果是itemlayout 为什么要用 第三行的top减第一行的top呢,不是应该返回layout的高嘛?没看明白
return getHeight() / visibleItems;
* Calculates control width and creates text layouts
* @param widthSize the input layout width
* @param mode the layout mode
* @return the calculated control width
* 计算布局宽
private int calculateLayoutWidth(int widthSize, int mode) {
initResourcesIfNecessary();
int width = widthSize;
int maxLength = getMaxTextLength();
if (maxLength > 0) {
float textWidth = FloatMath.ceil(Layout.getDesiredWidth("0", itemsPaint));
itemsWidth = (int) (maxLength * textWidth);
} else {
itemsWidth = 0;
itemsWidth += ADDITIONAL_ITEMS_SPACE; // make it some more
labelWidth = 0;
if (label != null && label.length() > 0) {
labelWidth = (int) FloatMath.ceil(Layout.getDesiredWidth(label, valuePaint));
boolean recalculate = false;
if (mode == MeasureSpec.EXACTLY) {
width = widthSize;
recalculate = true;
} else {
width = itemsWidth + labelWidth + 2 * PADDING;
if (labelWidth > 0) {
width += LABEL_OFFSET;
// Check against our minimum width
width = Math.max(width, getSuggestedMinimumWidth());
if (mode == MeasureSpec.AT_MOST && widthSize < width) {
width = widthSize;
recalculate = true;
if (recalculate) {
// recalculate width
int pureWidth = width - LABEL_OFFSET - 2 * PADDING;
if (pureWidth 0) {
double newWidthItems = (double) itemsWidth * pureWidth
/ (itemsWidth + labelWidth);
itemsWidth = (int) newWidthItems;
labelWidth = pureWidth - itemsWidth;
} else {
itemsWidth = pureWidth + LABEL_OFFSET; // no label
return width;
* Creates layouts
* @param widthItems width of items layout
* @param widthLabel width of label layout
* 创建布局
private void createLayouts(int widthItems, int widthLabel) {
if (itemsLayout == null || itemsLayout.getWidth() > widthItems) {
itemsLayout = new StaticLayout(buildText(isScrollingPerformed), itemsPaint, widthItems,
widthLabel > 0 ? Layout.Alignment.ALIGN_OPPOSITE : Layout.Alignment.ALIGN_CENTER,
1, ADDITIONAL_ITEM_HEIGHT, false);
} else {
itemsLayout.increaseWidthTo(widthItems);
if (!isScrollingPerformed && (valueLayout == null || valueLayout.getWidth() > widthItems)) {
String text = getAdapter() != null ? getAdapter().getItem(currentItem) : null;
valueLayout = new StaticLayout(text != null ? text : "",
valuePaint, widthItems, widthLabel > 0 ?
} else if (isScrollingPerformed) {
valueLayout = null;
} else {
valueLayout.increaseWidthTo(widthItems);
if (widthLabel > 0) {
if (labelLayout == null || labelLayout.getWidth() > widthLabel) {
labelLayout = new StaticLayout(label, valuePaint,
widthLabel, Layout.Alignment.ALIGN_NORMAL, 1,
} else {
labelLayout.increaseWidthTo(widthLabel);
* 重写onMeasure 设置尺寸
@Override
protected void onMeasure(int widthMeasureSpec, int heightMeasureSpec) {
int widthMode = MeasureSpec.getMode(widthMeasureSpec);
int heightMode = MeasureSpec.getMode(heightMeasureSpec);
int widthSize = MeasureSpec.getSize(widthMeasureSpec);
int heightSize = MeasureSpec.getSize(heightMeasureSpec);
int width = calculateLayoutWidth(widthSize, widthMode);
int height;
if (heightMode == MeasureSpec.EXACTLY) {
height = heightSize;
} else {
height = getDesiredHeight(itemsLayout);
if (heightMode == MeasureSpec.AT_MOST) {
height = Math.min(height, heightSize);
setMeasuredDimension(width, height);
* 绘制
@Override
} else {
canvas.save();
drawItems(canvas);
drawValue(canvas);
canvas.restore();
* Draws shadows on top and bottom of control
* @param canvas the canvas for drawing
* 绘制控件顶端 和底部的 阴影区域
* 需要传入画布对象
private void drawShadows(Canvas canvas) {
topShadow.setBounds(0, 0, getWidth(), getHeight() / visibleItems);
topShadow.draw(canvas);
bottomShadow.setBounds(0, getHeight() - getHeight() / visibleItems,
getWidth(), getHeight());
bottomShadow.draw(canvas);
* Draws value and label layout
* 绘制选中项 和 标签
private void drawValue(Canvas canvas) {
valuePaint.setColor(VALUE_TEXT_COLOR);
valuePaint.drawableState = getDrawableState();
Rect bounds = new Rect();
itemsLayout.getLineBounds(visibleItems / 2, bounds);
// draw label
if (labelLayout != null) {
canvas.save();
canvas.translate(itemsLayout.getWidth() + LABEL_OFFSET, bounds.top);
labelLayout.draw(canvas);
canvas.restore();
// draw current value
if (valueLayout != null) {
canvas.save();
canvas.translate(0, bounds.top + scrollingOffset);
valueLayout.draw(canvas);
canvas.restore();
* Draws items
* 绘制选项
private void drawItems(Canvas canvas) {
canvas.save();
int top = itemsLayout.getLineTop(1);
canvas.translate(0, - top + scrollingOffset);
itemsPaint.setColor(ITEMS_TEXT_COLOR);
itemsPaint.drawableState = getDrawableState();
itemsLayout.draw(canvas);
canvas.restore();
* Draws rect for current value
* 绘制中间的矩形区域
private void drawCenterRect(Canvas canvas) {
int center = getHeight() / 2;
int offset = getItemHeight() / 2;
centerDrawable.setBounds(0, center - offset, getWidth(), center + offset);
centerDrawable.draw(canvas);
* 触摸事件的 回调方法
* 看到了吧 如果适配器 adapter是null 的话,这里是什么都不会做的。
* 如果适配器不为空,将MotionEvent传递给手势识别器。 并判断是否已ACTION_UP
* 如果是说明操作已结束 调用justify()方法。
* return true. 不会泄露
@Override
public boolean onTouchEvent(MotionEvent event) {
return true;
if (!gestureDetector.onTouchEvent(event) && event.getAction() == MotionEvent.ACTION_UP) {
justify();
return true;
* Scrolls the wheel
* @param delta the scrolling value
* 滚动
* 好像只是重新定义了 scrollingOffset的值,
* 执行滚动的操作是这里吗?
* 先往后看吧。
private void doScroll(int delta) {
scrollingOffset += delta;
int count = scrollingOffset / getItemHeight();
int pos = currentItem - count;
if (isCyclic && adapter.getItemsCount() > 0) {
// fix position by rotating
while (pos < 0) {
pos += adapter.getItemsCount();
pos %= adapter.getItemsCount();
if (pos < 0) {
count = currentItem;
pos = 0;
} else if (pos >= adapter.getItemsCount()) {
count = currentItem - adapter.getItemsCount() + 1;
pos = adapter.getItemsCount() - 1;
} else {
// fix position
pos = Math.max(pos, 0);
pos = Math.min(pos, adapter.getItemsCount() - 1);
int offset = scrollingOffset;
if (pos != currentItem)
