当前位置:首页 > 电源 > 数字电源
[导读]本文介绍了采用dsPIC33 GS系列DSC的数字LED照明开发套件主要特性,数字LED照明开发套件和降压子板方框图,数字LED照明开发套件和升压子板方框图,基板接口电路图,基板电源电路图,基板DMX和模拟电路图,LED照明基板
本文介绍了采用dsPIC33 GS系列DSC的数字LED照明开发套件主要特性,数字LED照明开发套件和降压子板方框图,数字LED照明开发套件和升压子板方框图,基板接口电路图,基板电源电路图,基板DMX和模拟电路图,LED照明基板所用元器件表,以及降压子板电路图,升压子板电路图和数字LED照明开发套件材料清单。
dsPIC33F系列是高性能16 位数字信号控制器(DSC),采用改进型哈佛架构和C 编译器优化指令集,具有16 位宽数据总线和24 位宽指令,3.0-3.6V 时的工作速度达40MIPS,适用于多回路开关电源(SMPS)和其它数字电源转换器如AC/DC转换器,DC/DC转换器,功率因素修正(PFC),不间断电源(UPS),逆变器,嵌入电源控制器和数字照明等。
LED lighting applications supported by Microchip’s LED Lighting development Kit include dimmable LCD backlighting, signage, LED replacement of fluorescent tubes and incandescent bulbs, architectural lighting, and automotive lighting applications. Automotive lighting products include exterior applications, such as headlights, daytime running lights and signal lights.
Key features of Microchip’s Digital LED Lighting Development Kit include:
Color control for RGB LEDs
Supports DMX512 Standard for brightness control
Flexible input voltage support, including both Buck and Boost topologies
Fully dimmable
Full digital control
Fault protection
Fully controlled with a single dsPIC33FJ16GS504 DSC.
图1。数字LED照明开发套件外形图
The LED Lighting Development Kit can be used to demonstrate the capabilities of Microchips “GS” series of dsPIC Digital Signal Controllers (DSCs) in controlling multiple High Brightness (HB) LEDs. The development kit uses separate daughter cards for both buck and boost applications.
数字LED照明开发套件包括:
The LED Lighting Development Kit contains the following items:
• LED Lighting Development Kit Base Board
• Buck Daughter Card
• Boost Daughter Card
• Light Diffuser
• Information Sheet
图2。LED照明基板外形图
LED照明基板所用元器件表:
图4。数字LED照明开发套件和升压子板方框图
图5。基板接口电路图
图6。基板电源电路图
图7。基板DMX和模拟电路图
图8。降压子板电路图
图9。升压子板电路图
数字LED照明开发套件材料清单(BOM):
随着LED照明技术向多元化场景快速迭代,户外路灯、工业照明、智能调光灯具、多规格背光照明等设备对驱动电源的要求持续升级。传统LED驱动电源多采用PWM降压、Boost升压及LLC谐振拓扑,存在输出电压适配范围窄、轻载效率...
关键字: 照明技术 串并联谐振 驱动电源
近年来,高亮度LED照明以高光效、长寿命、高可靠性和无污染等优点正在逐步取代白炽灯、荧光灯等传统光源。在一些应用中,希望在某些情况下可调节灯光的亮度,以便进一步节能和提供舒适的照明。
关键字: LED照明
2025年11月26日 – 提供超丰富半导体和电子元器件™的业界知名新品引入 (NPI) 代理商贸泽电子 (Mouser Electronics) 即日起开售Silicon Labs的SixG301超低功耗IoT无线片上...
关键字: SoC IoT LED照明
在照明技术不断发展的当下,FP7122 内置 MOS 共阳极恒流调光芯片凭借其高效的恒流调光性能,在各类照明设备中得到广泛应用。然而,随着人们对节能环保以及电子设备电磁兼容性(EMC)要求的日益提高,准确测试 FP712...
关键字: 照明技术 芯片 恒流调光
差示扫描量热仪(DSC)与热重分析仪(TGA)是分析塑料部件受损和研究制造缺陷的最重要的热分析方法。
关键字: 差示扫描量热仪 DSC
在现代照明技术中,功率因数校正(Power Factor Correction,简称PFC)已成为不可或缺的一环。随着节能意识的提升和照明技术的不断进步,PFC在照明电路中的应用愈发广泛,其重要性也日益凸显。
关键字: 照明技术 功率因数校正 PFC
在LED照明技术日新月异的今天,可调光多用途大功率LED恒流驱动器成为了市场关注的焦点。其中,内置MOS开关降压型LED恒流驱动器以其高效、稳定、灵活调光等特性,在各类照明应用中展现出独特的优势。本文将深入探讨这类驱动器...
关键字: LED恒流驱动器 照明技术 降压型恒流控制
在LED照明行业蓬勃发展的今天,提升LED电源寿命成为了一个关键议题。作为LED灯具中不可或缺的组成部分,电源的稳定性与寿命直接影响着整灯的性能和可靠性。在众多电源元件中,电容器的选择尤为关键。传统上,电解电容因其大容量...
关键字: LED照明 多层陶瓷电容器 MLCC
随着LED照明技术的快速发展,中等功率LED作为连接大功率LED与低功耗LED的桥梁,在市场中占据了一席之地。尤其是在路灯、商业照明和室内照明等领域,中等功率LED因其相对较低的成本和适中的性能而受到青睐。然而,随着市场...
关键字: LED照明 中等功率 低功耗
发光二极管(LED)作为现代照明技术的重要组成部分,以其高效、节能、环保等优点在各个领域得到广泛应用。然而,在安装和使用LED时,正确区分并连接其正负极是确保LED正常工作、延长使用寿命的关键。本文将从多个方面详细阐述L...
关键字: 发光二极管 LED 照明技术
